-   -   How to remove a flathead screw (http://forums.pelicanparts.com/off-topic-discussions/323202-how-remove-flathead-screw.html)
Oracle 01-04-2007 10:02 PM
Hi,
I'll repaint the bumper of my beater truck but I'm stuck with those flathead screws.
If I try to undo the nut the screw turns..
How would you remove them? I don't mind destroying them cause I can replace with regular nut/bolt.
I have a die grinder @24K RPM is that enough or do I need to buy a dremmel... and what kind of attachment do I need? Or does anyone have any other ideas?
http://forums.pelicanparts.com/uploa...1167976138.jpg
Thank
Jasper
m21sniper 01-04-2007 10:43 PM
Air hammer/chisel baby. :)
http://img.epinions.com/images/opti/...resized200.jpg
trekkor 01-04-2007 10:52 PM
Weld a nut on the flat side so you hold a wrench on both sides.
KT
trekkor 01-04-2007 10:55 PM
You can prolly use a grinder with a cut-off wheel on the domed surface of the bolt. Then punch it through.
KT
TerryH 01-05-2007 03:54 AM
Those have a square shoulder that are supposed to keep it from spinning, but it appears rust probably allows it to turn now.
Grind the center of the head down to about 10%, then take a punch and big ******* hammer (BFH) and drive it downward. The rest of the head should bust off.
Zef 01-05-2007 04:56 AM
Drill it...engage an easy out bit...hold the nut...and unscrew it.
red-beard 01-05-2007 05:00 AM
Grind a slot in it for a flat head screwdriver. If that doesn't work, grind off the rest of the head.
stomachmonkey 01-05-2007 05:36 AM
leave it, paint over it, spend energy saved on a beer.
RickM 01-05-2007 07:04 AM
Yup, this is what I've done many times before. Cut off disc....big slot and big screwdriver.
Joeaksa 01-05-2007 07:10 AM
You need a dremel anyway. Get the ball bearing version. Mine has lasted me since 1975 and still going strong.
Oracle 01-05-2007 08:42 PM
Thank you all for your ideas.... I have to say I used them all from the air hammer/chisel to the grinder using the BFH and punch.
Finally the bumper is free and already painted... I don't have time to sand it and prep it I just cleaned all the loose paint and rust and painted over..
And I had to straighten the bumper... that was the main reason for the disassembly..
Thanks!!!
-J
