Using cell phone charger as a power supply?
I need 5 VDC to power a mobile experimental circuit. Is there a problem in using a car cell phone charger to do this? It's basically a DC-to-DC converter. How would the charger circuit live on a permanent basis? Is there a more elegant solution? I understand most chargers use an IC to limit ultimate current thus protecting sensitive circuits. My old cell phone required 5V 1A max (according to the charger jack on the phone) so I figured that unit's cell phone charger might work.
Thanks for any info you have. Sherwood |
Heck, I'd try it. I've also fried stuff, but that is part of the fun.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
My guess is that it isn't a good idea. Chargers run at higher voltage that straight power supplies, and they tend to play a lot with both voltage and current so they can avoid overcharging a battery. I would try something more like regular DC power supply wall wart or something first.
If you don't care about the potential to blow up your circuit, go for it. I would keep a close eye on things initially.
04 R1100SA (Pacific Blue metalic) 99 R1100SA (black) -- Totalled |
I disagree. A power supply for a cell phone is like a power supply for any other low voltage device. If the project requires 12V 1A and a cell phone 'charger' (transformer) fits those requirements, then it should work.
Dave
Senior Member
Island is somewhat correct about the voltage.
I have done what you are talking about with no problems. Take a digital VOM and read the output on the transformer. Usually a 5v output on a small transformer like this will read 6.5 or even 7v under no load, but drop down closer to its rated 5 volt output when placed under a load. Depending on your application I would get one that is very light duty, like 200 or 300 miliamps, or try one that size at first. The ones that are higher duty (say 500 miliamps) tend to go even higher on the unloaded voltage. Another option for power in this range is to find an old desktop power supply. They output 12 and 5 volts and are much more stable. Most of us electronic nerds have one or two of these around the house.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
If you want to use the computer power supply like Joe mentioned let me know - I've only got about 20 of 'em in the garage.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Thanks for the suggestion guys. I think I'm looking for more of a permanent solution, maybe part of a product down the road, so it must be low cost, vibration-proof and very adequate.
Did some research on the web last night, and the 12V power supplies/chargers for cell phones and MP3 players use an IC chip and a couple of capacitors, pretty compact. While MP3 players require more current, they operate on the same principle but with a more robust IC. I've got an old cell phone charger that I'll take apart and take a look. Will post a pic and see why they range from $.99 to $20. Sherwood |
Re: Using cell phone charger as a power supply?
Senior Member
Nice toys. Damm I miss having an electronics bench to work with!
Hi Rick,
Nice rig. I have only a version of your Fluke in my arsenal .... and limited electronics b.g. as a bonus. Does a 5V battery have to be on the receiving end to work for a long time (e.g. stabilize current, self-limiting, etc)? Sherwood |
Those old Fluke 8600As are available all over for $5 each but the 4 D Cell ni-cads that they all need are $6 each (+ shipping) |
Senior Member
Rick,
Where can you find the Fluke for that price? Looked on Ebay and they are $30 or so....
Senior Member
Thanks and I have enough "non-working" stuff around the house now! Want one that works...
Senior Member
Rick,
Am bidding on one on Ebay so would appreciate the link. Joe
With Internet Exploder when the error screen Quote:
The ROM file is how to program a small PROM to replace an obsolete part which you shouldn't need. If that doesn't work PM me your e-mail address and I'll send it to you. |
Senior Member
Rick,
Got all of them, appreciate the link. Question for you. Are the test leads on this meter the same as other digital VOM's or something special. As well if I find one that needs a battery or more do you have any sources? Thx, Joe A
The leads are plain old bananas.
D Cell ni-cads are kind of hard to find. I got them here but there may be a better price somewhere else. I think I convinced myself I couldn't use nickel metal hydride batteries. One D size 5000 mAh NiCd Rechargeable Battery Flat top with TAB Part#: CD-D5000TB (Qty: 4 x $5.65) Subtotal: $22.60 Tax: $0.00 S&H: $7.77 Final Total: $30.37 |
Senior Member
Thx much!
Sherwood, how you coming with your power supply?
