The Unsettler
stomachmonkey's Avatar
Quick excel help needed
Need an IF THEN OR formula for excel.
I need to calculate sales tax for 3 specific states, but not the other 47, that will be identified as NY, SC, OH so I need a formual that says "if (cell x) = NY then calculate sales tax based on the total amount column (cell y), else = 0
Make sense?
THX,
SCOTT
"I want my two dollars"
"Brandon Won"
Old 01-30-2007, 06:15 PM
Dept store Quartermaster
lendaddy's Avatar
I see what you're trying to do and am also interested in the answer as I haven't used those commands since my class in BASIC 20 years ago
One would think it would simply be. IF C6 = NY then (F6*1.08) or whatever, but I doubt it's that obvious. Then ofcourse you need the "otherwise (F6*1).
Cornpoppin' Pony Soldier
Old 01-30-2007, 06:21 PM
Semper drive!
rcecale's Avatar
I believe what you're looking for is actually an IF-THEN-ELSE function, or a "Nested IF" function.
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 01-30-2007, 06:30 PM
Flatbutt1's Avatar
Did you try the HELP function? for conditkonal IF,Then
A
15
9
8
Formula Description (Result)
=IF(A2=15, "OK", "Not OK") If the value in cell A2 equals 15, then return "OK". (OK)
=IF(AND(A2>A3, A2 =IF(OR(A2>A3, A2
The IF function uses the following arguments.
Formula with the IF function
logical_test: the condition you want to check
value_if_true: the value to return if the condition is true
value_if_false: the value to return if the condition is false
Function details
AND
OR
IF
big blue tricycle
stare down the darkness and watch it fade
Originally posted by Flatbutt1
Microsoft excel :tdown:
"Don't ever let someone tell you that you can't do something, not even me.''
"You got a dream, you gotta protect it. People can't do something, so they wanna tell you that you can't do it. You want something, go get it. Period.''
"If you think you can, you can. If you think you can't, you're right."
Old 01-30-2007, 06:33 PM
The Unsettler
Sorry, I'm working on little sleep.
Here's the formula,
IF(j2=10,"=sum(19.99*.0875)",0)
This works, the only problem I have is when you replace "10" with text "NY" I get #NAME as the output and it almost feels like the cell is not formatted properly.
"Brandon Won"
Old 01-30-2007, 06:35 PM
atlporsche's Avatar
= IF(logical test, value if true, value if false)
EDIT:
I'm thinking, =IF(OR(NY,SC,OH),(taxrate*total amt), 0)
you can just use the cell definition for the taxrate i.e. B4 and the cell definition fr the total i.e. G7.
I did something similar, and it worked pretty well.
sjd
Porsche sold, moving back to muscle cars for a bit.
Old 01-30-2007, 06:39 PM
Virginia Rocks!
VaSteve's Avatar
there's a couple of ways around it. Here's one to build on:
=IF(C11="ny",0.05,IF(C11="sc",0.06,IF(C11="oh",0.07,0)))
(Ohio has a high tax rate).
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 01-30-2007, 06:48 PM
atlporsche's Avatar
=IF(OR(A1="NY",A1="SC",A1="OH"),D1*E1, 0)
proven
sjd
Old 01-30-2007, 06:51 PM
atlporsche's Avatar
here's the data group.
NY 1665 45 37
SC 1665 45 37
OH 1665 45 37
CA 0 45 37
FL 0 45 37
OH 1665 45 37
SC 1665 45 37
Old 01-30-2007, 06:53 PM
Semper drive!
rcecale's Avatar
=IF(J2="ny",(19.99*0.0875),IF(J2="oh",(19.99*0.065),IF(J2="sc",(19.99*0.05))))
Change the 0.065 and 0.05 values for oh and sc (respectively) to whatever the correct numbers are.
Randy
One Marine's View
Old 01-30-2007, 06:56 PM
atlporsche's Avatar
http://office.microsoft.com/en-us/excel/HA012186941033.aspx?pid=CL100570551033
here's a link to returning multiple values from multiple inputs.
sjd
Old 01-30-2007, 07:01 PM
The Unsettler
Randy, that works perfectly, one thing, if the 3 conditions do not match (one of the other 47 states) it returns "False" which would be fine but I need to drop this into a database that will not accept false, can we make the formula spit out a value of 0?
"Brandon Won"
Old 01-30-2007, 07:07 PM
Virginia Rocks!
VaSteve's Avatar
Mine does.
Old 01-30-2007, 07:13 PM
jyl jyl is online now
jyl's Avatar
Basically you want to do something like
=IF([cell reference]="NY",[formula w/ sales tax],[formula w/o sales tax])
For example
=IF(A10="NY",B10*1.06,B10)
But you have to charge sales tax in three states, NY SC and OH? If it is the same tax rate in all states, then try
=IF(OR(A10="NY",A10="SC",A10="OH"),B10*1.06,B10)
If there is a different tax rate in each state, you can used nested IFs or a VLOOKUP table.
Nested IFs would be like
=IF(A10="NY",B10*1.06,IF(A10="SC",B10*1.065,IF(A10="OH",B10*1.07,B10)))
Nested IFs are ugly, so personally I would set up a 2-col x 3-row table with NY SC OH down one column and 1.06 1.065 1.07 down the other column. Suppose that table is located in cells I23:J25. Then
=IF(ISERROR(VLOOKUP(C23,$I$23:$J$25,2,FALSE)),1,VL OOKUP(C23,$I$23:$J$25,2,FALSE))
will give you 1.06 if C23 is "NY", 1.065 if it is SC, 1.07 if it is OH, and 1 if it is anything else.
The VLOOKUP approach lets you easily change the tax rates, add more states to tax, etc, and is way easier to read and debug than yucky nested IFs.
P.S. Wow, no shortage of responses, all posted while I was typing mine. Randy's formula needs a term telling it what to return if none of the IFs are true, i.e. if the state is not NY SC or OH, that is probably why you are getting the "False".
PM me your email and I will email you the spreadsheet I did to test the VLOOKUP method I posted.
Old 01-30-2007, 07:14 PM
The Unsettler
Thanks for the help guys.
I need to get some rest and do this again tomorrow. Running on 4 hours sleep in the last 48 hours.
I need to double check my sheet before I charge 200 orders to the wrong customers.
Word to the wise. If you are doing ecomm and need a merchant account use authorize.net Use them for 5 other sites and you can customize the order of the info in your batch file.
This project is using a different merchant account that has a strict format for the order of the fields but the data coming in from the call center does not match so I need to redo each batch file.
"Brandon Won"
Old 01-30-2007, 07:21 PM
Semper drive!
rcecale's Avatar
Try this one, Scott!
=IF(J2="ny",(19.99*0.0875),IF(J2="oh",(19.99*0.065),IF(J2="sc",(19.99*0.05),0)))
Cheers!
Randy
One Marine's View
Old 01-30-2007, 07:30 PM
jyl's Avatar
Get some sleep, you're way past the point of diminishing returns.
Old 01-30-2007, 07:36 PM
