I.E. Explorer keeps sending/receiving bytes after I press "x"
I.E. Explorer keeps sending/receiving bytes after I press "x" (on my XP operating machine. (No matter the site either)
Is it suppose to do this? Thanks
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
Does it send/receive a bunch or just a couple? When you hit the stop button IE tells the site "nevermind, stop sending me stuff" so that may be what you are seeing.
Normally when you hit the stop button I'd expect a flash or two on the network icon, but not more than 1 or 2 quick flashes.
Not to mention that there is other network traffic going on... if you really want to find out what it is, you'll need a packetsniffer.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
The icon keeps flashing, and additionally when I double click on the icon after pressing the x, the bytes keep going up.
Senior Member
Have you done a search using Ad Aware or Spybot? Try that and see what you have that most people do not realize are on their computer and sending info back to their home.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
The Unsettler
Re: I.E. Explorer keeps sending/receiving bytes after I press "x"
Use a different browser.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
I guess it depends upon how much it keeps flashing. If it flashes non-stop, then that might be a problem, but if it's just occasional, then probably not. XP is more complex and has more going on in the background that accesses the network than 98. You can check both your system tray (bottom right where the time is) to see what apps are running there. That may give you a clue. Also, you can check the processes that are running on your box. Hit ctrl-alt-del. You should either see the task manager or see a button that will pull it up. Once you are at the task manager choose "processes" Take the name of each process and do a google search for the process exactly as it is spelled in taskman. Stuff that you will probably see in XP lsass.exe, svchost.exe, svchost.exe, javaw.exe, etc.... Some of them will probably be listed a couple of times, like svchost. Don't freak if you have a big list. I have 53 processes listed right now. There are probably 5-10 for my printer, 5 or so for Trend Micro virus stuff, some for my firewall, some that are drivers for video, sound, mouse, scanner, etc.... Like I said, check each on google. Most processes these days are listed someplace on the net because people are so security conscious. So everyone is likely to be listed on some sort of security website.
Re: Re: I.E. Explorer keeps sending/receiving bytes after I press "x"
I checked the "processes" ,and yes there are many listed, one of them keeps fluctuating.....bigfix.ex. the CPU and then the Mem Usage keeps going up for bigfix.exe.
Re: Re: Re: I.E. Explorer keeps sending/receiving bytes after I press "x"
Well after about 10 minutes the icon appears to finally stop flashing.
Have about 45 "processes" Also, I notice a number of the processes have identical Image Names.
I did a search at www.google.com for bigfix.exe and this is what I found in the second link, http://www.auditmypc.com/process/bigfix.asp
Who knows, it could have been windows update checking for updates, it could have been bigfix looking for whatever it looks for. I'm betting that you could uninstall bigfix if you look for it in add/remove programs in control panel.
