Any way to limp along an HP imaging drum?
My all in one says to replace it and will not print, but it's not an in stock item locally. Is there some way to get a bit more life out of it?
drum is Q3964A |
Shake it...didn't you see the commercial!
There is a service key sequence that should reset the "replace drum" code. I don't have my service manuals any longer, but I may have it written down somewhere, Ill have to look.
What model printer is it? -Nick |
Let me do some looking, I know I have a stack of reset codes for service intervals, the task is finding them....
Let me get back to you... |
Thankfully my login still works on the HP site....
Unfortunately, that particular color drum has an internal counting unit that can-not be reset. Instead of the page count being stored in the printer memory, it is actually physically counted in the drum. Looks like the only option is to replace. Here is the HP store link: www.hp.com/buy/parts Sorry I couldn't provide a fix for ya :( -Nick |
The website at fixyourownprinter.com might help. A quick search showed this fix for a different model of HP Laser Jet. Might be worth a try:
"The drum life is supposted to be between 6000-8000 copies depending on how many color vs black only prints are made. I assume there is a chip on the drum unit which tell it when it should be replaced. One thing you can try, I do not know what will happen, but there is a NVRAM reset procedure which resets all the counts in ROM and places the machine back to factory default. This will not work if the drum uses a chip to tell when it is done. The NVRAM reset is done by powering off the machine. Press and hold the Go button. Turn the printer on and continue to hold the Go button. After the Go, Ready, and Attention LED's tuirn on, continue holding for at least 20 seconds. During this process, the Attention, Ready and Go LED's will each turn off. Release the Go button. The device LEDs will begin cycling from front to back. The NVRAM init process runs unitl the printer is in the Ready state." |
Geez guys, NOBODY thought of the obvious here... I'm really dissapointed..
[Buehler]Run the printer in reverse for a while, it should take off plenty of pages[/Buehler] "Thank you, I'll be here all week, tip your waitress" |
Thanks guys, I found a repair facility that had one in stock and convinced them to sell it to me.
Regards, Peter |
| All times are GMT -8. The time now is 01:19 PM. |
