Dept store Quartermaster
lendaddy's Avatar
Any way to limp along an HP imaging drum?
My all in one says to replace it and will not print, but it's not an in stock item locally. Is there some way to get a bit more life out of it?
drum is Q3964A
Cornpoppin' Pony Soldier
Old 02-06-2007, 11:07 AM
Shake it...didn't you see the commercial!
Old 02-06-2007, 11:10 AM
Greasy Member
many944s's Avatar
There is a service key sequence that should reset the "replace drum" code. I don't have my service manuals any longer, but I may have it written down somewhere, Ill have to look.
What model printer is it?
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 02-06-2007, 11:12 AM
lendaddy's Avatar
-Nick
Thanks! It's a HP Color LaserJet 2840.
Old 02-06-2007, 11:19 AM
Greasy Member
many944s's Avatar
Let me do some looking, I know I have a stack of reset codes for service intervals, the task is finding them....
Let me get back to you...
Old 02-06-2007, 12:33 PM
Greasy Member
many944s's Avatar
Thankfully my login still works on the HP site....
Unfortunately, that particular color drum has an internal counting unit that can-not be reset. Instead of the page count being stored in the printer memory, it is actually physically counted in the drum.
Looks like the only option is to replace.
Here is the HP store link: www.hp.com/buy/parts
Sorry I couldn't provide a fix for ya
-Nick
Old 02-06-2007, 12:46 PM
Friend of Warren
The website at fixyourownprinter.com might help. A quick search showed this fix for a different model of HP Laser Jet. Might be worth a try:
"The drum life is supposted to be between 6000-8000 copies depending on how many color vs black only prints are made. I assume there is a chip on the drum unit which tell it when it should be replaced. One thing you can try, I do not know what will happen, but there is a NVRAM reset procedure which resets all the counts in ROM and places the machine back to factory default. This will not work if the drum uses a chip to tell when it is done. The NVRAM reset is done by powering off the machine. Press and hold the Go button. Turn the printer on and continue to hold the Go button. After the Go, Ready, and Attention LED's tuirn on, continue holding for at least 20 seconds. During this process, the Attention, Ready and Go LED's will each turn off. Release the Go button. The device LEDs will begin cycling from front to back. The NVRAM init process runs unitl the printer is in the Ready state."
Kurt V
Old 02-06-2007, 12:48 PM
Super Moderator
cstreit's Avatar
Geez guys, NOBODY thought of the obvious here... I'm really dissapointed..
[Buehler]Run the printer in reverse for a while, it should take off plenty of pages[/Buehler]
"Thank you, I'll be here all week, tip your waitress"
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-06-2007, 01:27 PM
lendaddy's Avatar
Thanks guys, I found a repair facility that had one in stock and convinced them to sell it to me.
Old 02-06-2007, 01:35 PM
Friend of Warren
You're no fun!
Kurt V
Old 02-06-2007, 01:50 PM
  1. Purchase an imaging drum
  2. Lift the scanner assembly.
  3. Open the toner cartridge access door.
  4. Remove the dust cover.
  5. Open the front cover.
  6. Lift the two levers that hold the imaging drum.
  7. To remove the old imaging drum, pull it out of its slot.
  8. Unpack the new imaging drum. Place the used imaging drum in the bag and box for recycling.
  9. Remove the protective shield from the new imaging drum.
  10. Insert the new imaging drum into the printer.
  11. Lower the imaging drum levers.
  12. Close the front cover.
  13. Reinstall the dust cover.
  14. Close the toner cartridge access door. After you close the toner cartridge access door, the control panel displays the 'Initializing' message. Wait for the printer to stop calibrating before you proceed.
  15. Lower the scanner assembly.
Regards,
Peter
Old 02-09-2022, 09:11 PM
