-   -   Ack help! 3.2 Carrera values? (http://forums.pelicanparts.com/off-topic-discussions/329212-ack-help-3-2-carrera-values.html)
ChrisBennet 02-08-2007 05:05 AM
The dealer is obviously very attached to the car and really doesn't want to sell it. My last car was that color combo and I really liked it.
-Chris
KFC911 02-08-2007 05:38 AM
The dealer obviously doesn't give a crap about the car if he's using a Fram oil filter...I'm serious! Although it appears very nice, imo at that mileage & price, you can do better.
javadog 02-08-2007 05:47 AM
Here's my two cents,
I'd rather have a car with half that many miles and preferably one from someplace that is less wet than Washington. The high mileage on that car means that it was probably used as a daily driver in whatever weather and that sort of usage takes it's toll over time. A 911 will look pretty good on the outside and less wonderful if you start taking things apart. Even the cars with galvanized body metal will rust, where water gets trapped between panels. There are lots of these places.
The clicking sound when shutting the door is the door check. That needs to be fixed. I've seen cars with high miles fatigue the door jamb steel around the mounting points for the check and actually crack. Not good.
The car looks like it has been steam-cleaned underneath. Now you have no idea of what leaks. There are lot's of little picky things to be fixed, like the foglight lenses. Running around in wet weather with a busted lens will corrode the internal parts pretty quickly. If the obvious things aren't taken care of, the hidden ones won't be either.
Then, there is the engine. Has it had a top-end rebuild? These things run a long time but they won't run forever.
All in all, I'd be looking at lower mileage cars. The difference in price will usually be offset by lower costs once you own it. There is nothing so expensive as a 911 that needs "a few minor things" and thinking you can buy it cheap (not that this one is cheap-the price is quite high) and get it back to 100% yourself, with a few little weekend projects. I've been there and done that and I have several cars that are a labor of love and are financial black holes. I have a mentality that these cars deserve to be saved and that has cost me a ton of money. I actually own cars that have cost me 150% of the purchase price to "fix up" and I don't mean cars that have had paint jobs or engine rebuilds.
JR
Rot 911 02-08-2007 07:18 AM
$17K is crazy money for that car. Hell for that price I would sell you my '86 and drive the car up to you!
WolfeMacleod 02-08-2007 09:43 AM
I noticed that Fram too, and the lenses.
Drago 02-09-2007 07:55 AM
Nice Fram.
Wanna save $7K?
Same color, burgandy int., higher mileage, Targa.
Dueller 02-09-2007 10:59 AM
Bet you $10 if you ran a CARFAX you'd find that this dealer has only recently acquired this car. It appears to be an honest car, but 17K is silly money for an "honest" 170K mile car.
I represent a number of used car wholesalers/dealers. If he wanted to get top money he'd have spent $150-300 and have the interior detailed, new quality mats, gotten rid of the 90's cell phone, etc.
Get the vin and let someone here run a CARFAX...Unless he's had multiple wives I bet this is a 3-4 owner car.
$12K tops.
Nathans_Dad 02-09-2007 11:07 AM
At least you know the car is the same as when it was originally optioned. You have the Don Johnson white fuchs and the SUPA PIMP huge portable phone mounted to the shifter column. Check the cassette rack and see if there is some old Journey in there too!!
http://wolfetone.com/911/IMG_0466.jpg
P.S. $17k is crack smokin money for that car. I bought my 1984 Carrera 3.2 Targa with 62k miles on the clock for $14k 2 years ago. Coupes go for a little more than targas, but with 180k miles, that car is not worth more than $12-13k unless the engine/tranny has already been professionally rebuilt.
don911 02-09-2007 11:42 AM
I paid $17.5 for my 87 with 173K miles 7.5 years ago.
jyl 02-09-2007 06:27 PM
Pretty car.
Interior should have been detailed, probably will look like new with a good pro detail and new mats.
Make sure all the blue interior bits are okay, especially the dash pad, you won't find them at an affordable price.
Get a PPI. At 170K, the car could consume $14K of repairs or $4K. I would assume at least $4K, just refreshing the suspension will likely cost that much.
Lower valve covers have been replaced. Why? Leaks, top-end job, other?
Seems like various nuts and bolts and bits are corroded. Car was not garaged?
If PPI checks out, I'd try to get it for $15K. The dealer certainly expects to be dickered down by a couple grand.
ChrisBennet 02-09-2007 06:46 PM
I'll bite, how can you tell the lower valve covers have been replaced?
-Chris
WolfeMacleod 02-09-2007 08:12 PM
Just did that, actually.
Date: Mileage: Source: Comments:
04/13/1994 125,769 Washington
Motor Vehicle Dept.
Edmonds, WA
Title #9410315108 Title or registration issued
04/14/1994 Washington
Motor Vehicle Dept.
Edmonds, WA
Title #902553002894104 Title or registration issued
08/28/1997 147,000 Washington
Inspection Station
Edmonds, WA Passed emissions inspection
08/05/1999 161,000 Washington
Inspection Station
Lynnwood, WA Passed emissions inspection
09/12/2001 Washington
Motor Vehicle Dept.
Edmonds, WA
02/09/2007 Porsche Cars North America No recalls open for repair.
The owner of the dealership tells me it's his personal car. From the paperwork he has, his story appears to check out. The paperwork from the local shop is the previous previous owner. It hasn't been driven for QUITE some time, as the plates are tagged for '02, and it has been garages.
In the pictures of the Enging bay, it appears there is rust above the engine, on the body. This brown stuff is NOT rust. I looked at it today. It reminds me of grease splattered onto a pan. You can scrape it off with your fingernail with some effort.
I drove the car today. WHile I am not real familliar witht he drivings of a 911, it seemed to drive GREAT.
I'll be checking out Drago's Targa tomorrow...
Dueller 02-09-2007 08:26 PM
Well I owe you $10:confused:
WARNING: Even a high mileage 20 year old 911 with worn suspension will drive, ride and handle better than what most people are used to. Ride in one with a fresh suspension and it will astound you.
Like I said...its an honest 170K mile car. I just personally don't think its a $17K car. Also in the past 8 years its been driven only 9,000 miles? Hmmmmmmmm :rolleyes:
WolfeMacleod 02-09-2007 08:45 PM
Pay up, Bub! :D
Don't know why he parked it, really. I think maybe he's more of a muscle car guy, as I've seen plenty of Mopar stuff there. We asked about a Challenger that was there awhile back, and he said "not for sale, it's mine"
There was a stupid-nice old "Iforget" there today. Freaking sweeet. Umm..Chev..Forrr..must..novvv...errr...Camaro, that's what it was..
nostatic 02-09-2007 08:57 PM
it has been sitting since '02? Budget at least $3K to get it up to snuff, and more like $5K.
this thing is WAY overpriced. I'd run, not walk away from it unless it was well south of $15K.
Dueller 02-09-2007 09:59 PM
OK, Wolfie....
One other thing...NEVER EVER EVER buy a used car in the rain. Which for you fokkers in the PNW means you can only buy a car during a 16 day window in July;)
I'd be really curious where he had it serviced...bet its "Oh I know a guy who does it on the cheap for me...."
jyl 02-09-2007 10:14 PM
-Chris
Look like turbo valve covers.
WolfeMacleod 02-09-2007 10:25 PM
OK, Wolfie....
I learned that when we bought my 924S. There was a little body damage we didn't notice, behind the right rear wheel, down near the bottom. Very little, like someone knee'd it or something. Hell, it's hard to spot, even in the dry.
The place it had been serviced is called Akers. They've been mentioned here by people before.
Dueller 02-09-2007 11:38 PM
Well, dayum, I'm just wrong all the way aroumd.
It is a pretty car. I purxhased a 87 Carrera about 5 years ago in North Georgia. 81K miles, interior in similar condition as the one you're looking at, never wrecked but had had some touch up paint work (rock chips on hood, door dings fixed, etc). Not concours but presentable. A few small oil leaks but brand new tires, recent service, etc. Asking 19K; paid $15K.
The headliner on the sunroof was torn so I ended up replacing it all. Old windshield cracked so I replaced i. A few other odds and ends and I had another $2K in it by the time I got it right.
Drove it pretty much daily for 60K miles with no problems. Decided to freshen the motor as oil consumption was going up. Fortunately (for me at least) I represented the best Pcar technician in his divorce so we bartered on a complete top end rebuild, including a lot of "while you're in there stuff like crank sensors, all oild lines, clutsh, cat gypass, transmission upgrades, AC conversion to R134 etc etc etc). North of $12K if I had paid for everything.
Now it is mechanically perfect but the daily use has taken its toll on the interior, original paint. I'd value it at 12-14 but looking at prices recently. I dunno.
So I'm keeping and plan to retire it from daily us. Since I love drivimg it I'm gonna upgrade the suspension and pit it on a diet rather than do a stock cosmetic restoration.
Good luck on yuour quest
450knotOffice 02-09-2007 11:40 PM
Re: those valve covers. Porsche introduced that particular design in 1980 on the SC. It was a re-enforced version of the original horizontally ribbed version introduced on the Turbo in '75 and all other 911's during mid-year '75. It solved a long running leak issue with the older designs. All 3.2 liter Carreras came with those valve covers.
