-   -   One-off W9 motor built as a thesis project. INSANE (http://forums.pelicanparts.com/off-topic-discussions/330041-one-off-w9-motor-built-thesis-project-insane.html)
Wrecked944 02-12-2007 11:30 AM
http://www.atomracing.se/W9/W9_engine_3.jpg
Here is the website...
http://www.atomracing.se/6M.html
:eek:
fastpat 02-12-2007 11:51 AM
That's a stunningly beautiful piece of industrial art. Thanks.
arcsine 02-12-2007 12:04 PM
"Max power (est.): 526 hp@ 10700 rpm (bmep: 14,6 bar ; 211 psi), dimensioned for Tri-Turbo 1005 hp" from a 2.7L! Would love to hear it run.
For a MS thesis project, someone has a deep pockets or really good finding.
Zeke 02-12-2007 04:45 PM
Now that I would put in the back of a 911.
Icemaster 02-12-2007 05:05 PM
Not sure it would fit.
Nontheless, wow.
Hugh R 02-12-2007 05:40 PM
Stunning! I'd love to see how it actually works.
fastpat 02-12-2007 06:21 PM
I'd love to hear it run, nine cylinders must make some kind of music as they pass through 8k looking for 10k.
SanDiegoDon 02-12-2007 06:38 PM
+1
legion 02-12-2007 06:45 PM
I used to own a 5 cylinder MB 300D.
To this day, if there is a 5 cyl. MB within a half mile, I can pick it out.
I'd imagine that a 9 cyl. engine would have a similarly distinct sound.
2.7RACER 02-15-2007 10:41 PM
Interesting engine.
With the 60-0-60 layout, it seems the firing order is not evenly spaced.
That is 6 of the cylinders would fire 240 crankshaft degrees apart, the outside cylinders. The 3 center cylinders would fire between every two outside cylinders, giving an uneven pulse.
That is, said another way, at 0, 60, 120, 240, 300, 360 480, 540 & 600 crankshaft degrees.
One outside bank firing at 0, 240 & 480 degrees.
The other outside bank firing at 120, 360 & 600 degrees.
The center bank interspersed at 60, 300 & 540 degrees.
Leaving gaps at 180, 420 & 660 degrees.
Am I missing something?
Joeaksa 02-16-2007 12:25 AM
I want to hear it run... sure looks nice.
beepbeep 02-16-2007 05:47 AM
The guy is from Luleå. That explains it. Too much snow and too little to do. :D :D
svandamme 02-16-2007 06:14 AM
speaking of which , whatever happend to Project Lumina??
beepbeep 02-16-2007 06:22 AM
Mattias became father so he wanted to get rid of the car. I just bought a flat so I didn't have the time to finish it. I still have some bits and parts over so I just need to settle down before diving into car project again.
1967 R50/2 02-16-2007 08:27 AM
3/8ths of a radial engine.
M.D. Holloway 02-16-2007 08:35 AM
Janus, that is too cool! That kid must have some deep pockets or access to some serious equipment. I have to think it was heavily funded by an auto maker.
It got me wondering and thinking about other W engines. Here is one from VW. Some of you may have seen it. It is in production. Here is the site: www.seriouswheels.com/cars/top-VW-W12-Roadster.htm
a W12! Janus thanks agian for making me wonder!
http://forums.pelicanparts.com/uploa...1171643641.jpg http://forums.pelicanparts.com/uploa...1171643678.jpg
http://forums.pelicanparts.com/uploa...1171643703.jpg
M.D. Holloway 02-16-2007 08:36 AM
opps...here is the engine in:
M.D. Holloway 02-16-2007 08:38 AM
http://forums.pelicanparts.com/uploa...1171643894.jpg
fastpat 02-16-2007 08:46 AM
That engine is quite a bit different in that is is a "Double V" engine instead of a "W" engine. Each of what appears to be a bank is in reality a V-6 with only 15 deg. between each bank, with a common head. Interesting layout. And, the article says there's a "Double V" 16 cylinder model as well. The mind boggles.
cashflyer 02-16-2007 02:13 PM
I've run plenty of 9 cylinder engines.
But they were all round.
