1974 karmann ghia auto stick
i know this is a porsche site but at a lost where to go problem i took out the auto stick looking for the syncros and was advised wrong now i cant adjust it right to get in any gears does anyone know how this is done how to adjust this thing since it comes close to the sparkomatic thks
Start with the switch on the shifter, then check all the vacuum hoses and the reservoir for any leaks.
Also has the shift coupler been properly adjusted? Can you get it in gear when it's not running?
68 911L |
caan get it in gear when its not running but when running dosent go into any gears its semi aoto didnt see any vacumm lines this just happoened when i pulled the ****er rod out ol the cradle has a plate underneath seems the shifter and plate must be alighned rigth thks for any help
Vacuum lines are located off the intake manifold and run to servo that moves the clutch arm. if you don't have enough vacuum the arm does not move enough to engage the clutch. If the switch is faulty on the shifter nothing will work, it uses that signal from the switch to move the servo and engage the clutch.
68 911L |
this is what i know so far vacuum lines are good no leaks but that does not tell me mutch it ****ed better before i removed the shifter but now it dosent shift well grinds the hell out of the gears goes into park no problem now as far as the switch goes there is a wire going into the rod itself not connected at this point broke off but i think its a ground for the reverse lights not sure though get me thinking it can be the servos hope not dont want to get that much into the tranny though the pics in my early porsche manual shows the tranny very similar
Get a Bentley manual for Type 1 VW to '79. It covers the semi-auto.
http://www.bentleypublishers.com/product.htm?code=v179
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 03-11-2007 at 05:36 PM.. |
auto stick
will do thks
The switch should have a ground and signal wire, on the 911 the ground is connected to one of the bolts that holds the shifter to the tunnel. The signal wire is routed through the tunnel, the wire in the tunnel can easily drop back in and you must remove the shifter to retrieve it.
68 911L |
thats exactly the wire that is disconnected thks that i think will cure most of the problem the other problem will be lining up the ****er to get all gears its not just a drop in, also what is the widest porsche rimsthat can be used with this car?
