Dept store Quartermaster
lendaddy's Avatar
Padlocks are so easy to pick it's stupid. You don't even need to really "pick" them, just apply turning torque to the cylinder and rake the pins with a wavy wire.
Easy as pie.
Cornpoppin' Pony Soldier
Old 03-15-2007, 01:05 PM
Senior Member
Superman's Avatar
I'm pretty good wth tools usually, but I have always been powerless against those Kryptonite locks.
Mocha 1978 911SC. "Coco"
Old 03-15-2007, 03:42 PM
Detached Member
Hugh R's Avatar
Dremmel tool and cutoff disk for hardened steel, 30 seconds and it was off, thanks guys.
Hugh
Old 03-16-2007, 08:31 PM
Driver
Noah930's Avatar
Phew. That makes me feel safe.
Maybe I can start using about 10 of 'em on each bike/motorcycle I own. Make the thief work for at least 5 minutes to steal the thing.
1990 Black 964 C2 Targa
Old 03-16-2007, 10:35 PM
Control Group
Tobra's Avatar
You just need to wear lead gloves
Originally posted by competentone
Warts can be defeated with a scissor jack????
You really have to explain this to us!
The trick is to get the jack between the wart and the basement membrane, otherwise you leave a scar
Old 03-16-2007, 10:36 PM
"O"man(are we in trouble)
widgeon13's Avatar
reciprocating saw w/ carbide blade, then if someone gives you any shlt when your stealing (getting your daughter's bike free) just turn the saw on them.
Old 03-17-2007, 08:47 AM
the the is offline
Do you have a pic of the disc you used??
I've never been able to cut anything harder than a paperclip (ok a very small bolt) with my Dremel, using discs like this:
After reading your post, I did some searching. Did you use something like this?
Old 03-17-2007, 08:54 AM
Team California
speeder's Avatar
The flat fiberglass cut-off wheels for a Dremel tool will go through hardened steel on a padlock like a hot knife through butter. Well, like butter with a lot of sparks shooting out.
I don't have a picture handy, but the discs I'm talking about resemble a very flat 50 cent piece.
Denis
Old 03-17-2007, 09:09 AM
Team California
speeder's Avatar
Here's a picture of the disc I use:
Denis
Old 03-17-2007, 09:16 AM
Detached Member
Hugh R's Avatar
The same disk that Denis (Speeder) used, worked great.
Hugh
Old 03-20-2007, 06:07 AM
