WRX alignment question
The tires on just the left side of the car wear on the outside edge, kind of cupped. The right side wears perfect. Would this alignment cause that?
How is caster specified? The service manual specifies caster tolerance as (common difference +/- 45 minutes).
Does the left caster being at the limit mean the wheel is pushed back, like it hit something?
Do you think they adjusted the toe in on the front or just turned the steering wheel a little?
Here is what the service manual says it should be for a Turbo Sedan... See if my terminology is correct
Front
Camber (tolerance +/- 45 minutes) Should be -25 minutes Mine is
  • LEFT -0.6 degrees or -36 minutes
  • RIGHT -0.2 degrees or -12 minutes
Caster (common difference +/- 45 minutes) (what does common difference mean?) Should be 3 degrees 35 minutes Mine is
  • LEFT 2.8 degrees or 2 degrees 48 minutes(2 minutes out?)
  • RIGHT 3.1 degrees or 3 degrees 6 minutes
Toe-in Should be 0 +/- 3 mm (Each toe angle: +/- O deg. O7' 30”) (Total toe angle: +/- O minutes15 seconds) Mine is
Kingpin angle (assume that is SAI) (tolerance: +/- 45 minutes) Should be 14 degrees 35 minutes Mine is
  • LEFT 14.5 degrees or 14 degrees 30 minutes
  • RIGHT 14.6 degrees or 14 degrees 36 minutes
Rear
Camber (tolerance +/- 45 minutes) Should be -1 degree 30 minutes Mine is
  • LEFT -1.4 degrees or -1 degree 24 minutes
  • RIGHT -1.5 degrees or -1 degree 30 minutes
Toe-in Should be 0+3 mm (Each toe angle: +/- O deg. 7 minutes 30 seconds) (Total toe angle +/- O"15') Should be -25 minutes Mine is
  • LEFT .02 degrees or 1 minute 12 seconds
  • RIGHT 0 degrees
Old 03-22-2007, 11:29 PM
slodave's Avatar
Can't answer your question, but an ex-coworker of mine bought a new Subaru 4 door turbo. A few weeks of driving and he developed a problem. He had to bring it into the dealer and they apparently had a really hard time getting it aligned properly. Took them a few days to get it right.
Good luck!
Dave
Old 03-22-2007, 11:49 PM
It's simple. Take it to a (competent) WRX suspension tuner. Should be easy to find one (through nasioc or somewhere) in your area.
Pay the man ~$120 for a decent alignement and enjoy the results. I did when I bought mine (new). They all benefit from a proper setup.
Audi B7 S4
Old 03-23-2007, 04:02 AM
I was trying to understand what the alignment process was.
nevermind.
Old 03-23-2007, 07:44 AM
Driver
Noah930's Avatar
Don't understand your question, exactly. According to the printout, your alignment looks OK, now. All "actual" (presumably meaning "current"?) numbers are within the tolerance ranges. As long as they didn't input the wrong vehicle into the computer, I'd think that that's OK.
Doubt they would "just turn the steering wheel a bit" to make a change. At least, that's not how it's supposed to be done. Don't think the lasers and computer would let that work.
Don't know where you're getting your tolerance values that you've published, as they don't match what the computer printout reads.
What do you mean by "cupped?" Both front and rear tires? A little too much toe-in could cause accelerated wear at the outer shoulders of a tire. Cupping usually means that there's an actual concavity to the wear pattern. Is that what you're experiencing?
1990 Black 964 C2 Targa
Old 03-23-2007, 01:36 PM
RallyJon's Avatar
Set the front to zero toe and up to -1º camber on each front if they can get that much.
Your symptom says too much toe-in or too little camber. The alignment numbers don't show that, but who knows.
And there are a lot of complete bozos running high tech alignment equipment. Don't like what you're getting? Go somewhere else.
993 · 911 · STI · S4 · rally car
Old 03-23-2007, 01:50 PM
