Eric 951's Avatar
disabling the seatbelt warning Audi A4
My GF has an '06 A4 and I am wondering if anyone knows how to disable the seatbelt chime. It is annoyiong as all get out-since if the car is running and you are sitting in the seat and the belt is not fastened it dings/flashes. This is fine if the car is being driven, but is annoying if you are sitting in the driveway doing maintenance, or are at the bank/ATM drive-thru and need to remove the belt for any reason.
On many newer cars(my truck for example) there are specific methods for disabling the chime--but I cannot find anything in realtion to the Audi.
Anyone know a procedure?
Eric
83 911SC/83 944
bunch of Honda 750s
Old 04-24-2007, 11:47 AM
A quick Google turns this up:
"You have to reprogram the ECU with a VAG-COM"
"Vag-Com solution:
Remove nagging seatbelt chime
Log onto block 17 - instruments.
Recode with module by subtracting 2 from your current number."
Looks like you'll need to go to a repair shop, tuner (or perhaps dealer) and have them reprogram for you. The VAG-COM unit goes for around $200.
Warren & Ron, may you rest in Peace.
Old 04-24-2007, 12:00 PM
gprsh924's Avatar
"VAG-COM"
that is simply a great name
Garrett
Living and Thriving
Old 04-24-2007, 01:27 PM
Information Junky
island911's Avatar
I would attack the problem at the seatbelt latch. It's just a switch in there ... make it stick.
Old 04-24-2007, 02:37 PM
