-   -   Basic air compressor advice (http://forums.pelicanparts.com/off-topic-discussions/343278-basic-air-compressor-advice.html)
FastCarFan 04-25-2007 06:47 PM
I would like to buy a basic air compressor for my garage. I only want it to put air in car tires. I have no need for it to power tools.
I do not want to use the compressor in the trunk of my 911. I have heard that they are very slow & I don't want to get it out everytime I want to put air in tires, especially in the winter when the 911 is covered up.
What brands/models do you recommend?
What do you think of this one? http://www.sears.com/sr/javasr/product.do?cat=Compressors+%26+Air+Tools&pid=00915 239000&vertical=TOOL&subcat=Air+Compressors+%26+In flators&BV_UseBVCookie=Yes
Is it good enough for my needs?
What specs should I look for? I know absolutely nothing about compressors.
Thanks for your help.
Paul K 04-25-2007 07:11 PM
I have one of these;
http://www.sears.com/sr/javasr/product.do?cat=Compressors+%26+Air+Tools&pid=00915 310000&vertical=TOOL&subcat=Air+Compressors+%26+In flators&BV_SessionID=@@@@0209849633.1177553149@@@@ &BV_EngineID=ccekaddkkhklmmecefecemldffidfko.0
Like you, I only wanted one to fill tires. It works great- and I got it on special so it was only $100.
For the few extra bucks, I'd probably 'upgrade' to the one I got. Hopefully someone else will chime in...
Paul.
masraum 04-25-2007 07:39 PM
do a couple of searches. There are a couple of really extensive threads about what to look for in a compressor.
masraum 04-25-2007 07:44 PM
http://forums.pelicanparts.com/showthread.php?s=&threadid=281457&highlight=air+co mpressor+cast+iron
http://forums.pelicanparts.com/showthread.php?s=&threadid=192865&highlight=air+co mpressor+cast+iron
http://forums.pelicanparts.com/showthread.php?s=&threadid=192373&highlight=air+co mpressor+cast+iron
http://forums.pelicanparts.com/showthread.php?s=&threadid=136734&highlight=air+co mpressor+cast+iron
http://forums.pelicanparts.com/showthread.php?s=&threadid=52352&highlight=air+com pressor+cast+iron
FastCarFan 04-26-2007 02:44 PM
Thanks. I purposely did not use the search function because the compressor postings I have read all dealt with much larger compressors (for tools) than I need.
Thanks Steve for the links. I will check them out.
What I don't want to do is get a compressor to fill tires & find that it is too cheap/slow/loud or that isn't even powerful enough to fill tires.
MikeSid 04-26-2007 03:14 PM
If you are just filling tires, get a foot pump with a dial guage.
I bet you could find a decent one for under $20.
Seahawk 04-26-2007 04:04 PM
Re: Basic air compressor advice
Your link and Paul's below yours will work great...I have a similar model that I've owned for almost a decade:eek:
RickM 04-26-2007 04:10 PM
For a few bucks more I'd spring for the 12 gal model (as opposed to 3). You'll get alot more use out of it for the small increase in $$$. http://www.sears.com/sr/javasr/product.do?cat=Compressors+%26+Air+Tools&pid=00916 640000&vertical=TOOL&subcat=Air+Compressors+%26+In flators&BV_UseBVCookie=Yes
