Mailing POR-15, what is flash point?
Hi,
I want to mail a 4 ounce can of POR-15. I know I meet the size requirement but the post office mention it had to below a certain flash point. Anyone know what it would be? Thanks, David |
POR delivers by mail all the time. Why the concern?
Because I asked the person at the PO and she mentioned the requirements.
Thanks. |
From their MSDS:
http://www.imperialrestoration.com/product_images/pormsds.pdf IV. FIRE & EXPLOSION HAZARD DATA FLASH POINT (Method used): TCC 104 Degrees F EXTINGUISHING MEDIA: Dry chemical (e.g.monoammonium phosphate, potassium sulfate, and potassium chloride, carbon dioxide, high expansion (proteninic) chemical foam, water spray for large fi res. SPECIAL FIRE FIGHTING PROCEDURES/USUAL FIRE OR EXPLOSION HAZARDS: Full emergency equipment with self-contained breathing apparatus should be worn by fi refi ghters. During a fi re, MDI vapors and other irritating, toxic gases may be generated by thermal decomposition (see section VIII). At temperatures greater than 400 degrees F (204 degrees C), polymeric MDI can polymerize and decompose. Use cold water to cool fi re-exposed containers. HAZARD CLASS: B HEALTH: 3 FIRE: 2 REACTIVITY: 1 FLAMMABLE LIMITS LEL: 1% FLAMMABLE LIMITS UEL: 7.1% |
Thanks for your help. This is perfect.
It has to be above a certain minimum flash point, It it was below it would be deemed hazardous and unshippable.
| All times are GMT -8. The time now is 10:00 PM. |
