Mailing POR-15, what is flash point?
Hi,
I want to mail a 4 ounce can of POR-15. I know I meet the size requirement but the post office mention it had to below a certain flash point. Anyone know what it would be? Thanks, David
77 Carrera 3.0 |
Slumlord
POR delivers by mail all the time. Why the concern?
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Because I asked the person at the PO and she mentioned the requirements.
Thanks.
77 Carrera 3.0 |
Slumlord
From their MSDS:
http://www.imperialrestoration.com/product_images/pormsds.pdf IV. FIRE & EXPLOSION HAZARD DATA FLASH POINT (Method used): TCC 104 Degrees F EXTINGUISHING MEDIA: Dry chemical (e.g.monoammonium phosphate, potassium sulfate, and potassium chloride, carbon dioxide, high expansion (proteninic) chemical foam, water spray for large fi res. SPECIAL FIRE FIGHTING PROCEDURES/USUAL FIRE OR EXPLOSION HAZARDS: Full emergency equipment with self-contained breathing apparatus should be worn by fi refi ghters. During a fi re, MDI vapors and other irritating, toxic gases may be generated by thermal decomposition (see section VIII). At temperatures greater than 400 degrees F (204 degrees C), polymeric MDI can polymerize and decompose. Use cold water to cool fi re-exposed containers. HAZARD CLASS: B HEALTH: 3 FIRE: 2 REACTIVITY: 1 FLAMMABLE LIMITS LEL: 1% FLAMMABLE LIMITS UEL: 7.1%
Thanks for your help. This is perfect.
77 Carrera 3.0 |
It has to be above a certain minimum flash point, It it was below it would be deemed hazardous and unshippable.
"The smaller the fine print, the larger the risk." 1988 911 coupe 2008 VW R32 2004 530I |
