| Registered |
				Alternative vehicle propulsion
			've been thinking that after I pay off the Boxster, I will buy a more 'practical' and efficient car to use as a daily driver. I actually used to have a Honda Insight, and it was a good little car. I averaged 55mpg, and got up to 68mpg on a couple road trips up to 72mpg. However, I moved to an apartment 2.1 miles away from work, and the poor little thing didn't have enough running time to regenerate itself. Lately, I've seen a bit more about plug in hybrids, and serial hybrids. The Prius is supposed to be updated for the 09 model to be a plug in hybrid, and I believe it will have a certain range it can go on electric power alone. Also, the Chevrolet Volt concept looks interesting. It also looks like the way to go: An electric car with a small generator onboard to extend it's range. Then today I stumbled upon this bad boy: http://www.worldcarfans.com/news.cfm/country/ecf/newsID/2060724.006/mini/pml-builds-640hp-electric-mini A BMW Mini (Cooper) that was converted to electric (serial hybrid). 160hp motors in each wheel.... up to 250 mile range on a charge, with a small generator on board to extend it's range and charge itself.... ... and it does 0-60 in 4.5 seconds!! The company that built it says the system would be adaptable to other vehicles relatively easily. I can imagine a Boxster set up that way! 640HP to the ground, all wheel drive, electronic traction control, and a good range! What say you? If you could buy something like the Mini with that powertrain, and say, it cost $30k or so... would you buy something like that for a commuter car? If it cost around $10k, would you convert a Boxster? I think I would!!
				__________________ Matt J. 69 911T Targa - "Stinky" 2001 Boxster "Stahlgewehr" Last edited by FrayAdjacent911; 05-17-2007 at 12:55 PM.. | ||
|  05-17-2007, 12:07 PM |
| Registered |
				Re: Alternative vehicle propulsion
 Try this link, the other one was too long or something. http://www.worldcarfans.com/news.cfm/country/ecf/newsID/2060724.006/mini/pml-builds-640hp-electric-mini
				__________________ 1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect | ||
|  05-17-2007, 12:33 PM |
| Registered Join Date: Mar 2003
			If you only live 2.1 miles to work, get a bicycle. I have a long commute - 20 miles of either interstate or backroads, with a total of 3 stop lights. I think I'd like one of the Smart cars (or sparrows or whatever they are called) little 2 seaters wtih motorcycle engines.
				__________________ “IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” | ||
|  05-17-2007, 12:34 PM |
| Registered | Quote:
 If I had back roads or residential streets, I'd probably get a little moped or something.
				__________________ Matt J. 69 911T Targa - "Stinky" 2001 Boxster "Stahlgewehr" | ||
|  05-17-2007, 12:53 PM |
| Registered |
			Fixed the link
|  05-17-2007, 12:55 PM |
