Cars & Coffee Killer
legion's Avatar
Welding Brass
Is it possible to weld brass?
5 liters of VVT fury now
-Chris
Old 06-27-2007, 07:46 AM
Dept store Quartermaster
lendaddy's Avatar
Sure, electrobrazing or brazing is easy. What is the piece?
Cornpoppin' Pony Soldier
Old 06-27-2007, 07:49 AM
legion's Avatar
My 951 uses a toothed cable to drive the sunroof mechanism. The motor is in the trunk, and a brass tube containing the cable runs up to the sunroof. There is a mounting flange on the tube that was welded (or is it brazed?) on, and it has broken free. Consequently, the tube just pushed away from the sunroof mechanism when to motor runs, rather than driving the gears to raise the roof.
-Chris
Old 06-27-2007, 07:53 AM
lendaddy's Avatar
JB Weld Seriously it will probably work.
I don't know if you want flame for brazing in the area and electrobrazing takes some practice and setup (basically MIG like welding on brass), it's easy to blow holes though.
Old 06-27-2007, 08:00 AM
legion's Avatar
I have the whole assembly removed from my car. Could I take it to a machine shop to fix? We are talking a weld that is 3mm long here. What could I expect for it to cost?
-Chris
Old 06-27-2007, 08:04 AM
lendaddy's Avatar
If it's out then sure a place could braze it easily. Maybe a 12 pack of beer or $20-$40 tops. Clean the area with a wire brush real well first for them, they'll like that and be more willing to quickly do it for you.
Old 06-27-2007, 08:06 AM
GO DAWG GO's Avatar
Legion,
Brass is "Brazing". Consider this; You can get a good quality silver based solder and solder it with a Propane torch. Apply some good quality acid flux first. Then clean it thoroughly to remove the acid from the crystaline pours of the brass. If you dont, it will continue to corrode.
1 bad 930
MattKellett's Avatar
Legion - I'm with Robert on this one, silver solder would work just fine, even a regular solder would probably work, easy to try and if it doesnt do the job, you could then explore other options. Heating with a small torch or even an electric stove top if you have one would do the trick.
Good luck
Matt
Matt Kellett
87 Carrera Coupe - Marine Blue
60 MGA - Chariot Red
66 Jaguar MKII - Sherwood Green
09 VW GTI - Candy White
Old 06-27-2007, 08:29 AM
canna change law physics
red-beard's Avatar
MAPP gas Brazing rod and flux...
James
Red-beard for President, 2020
Old 06-27-2007, 08:37 AM
legion's Avatar
I will try silver soldering...
-Chris
Old 06-27-2007, 09:17 AM
GO DAWG GO's Avatar
Chris,
Clean the hardware before hand using a degreaser or solvent. Remove all foreign matter Paint grease etc. because it will effect the inter-mechical bond of the silver/tin. Good luck!
P.s. As you know my typing and grammar frequently suffer because of my haste, But I am actually pretty good at fixing things as my peers claim. I have many learned tricks and always willing to share.
Bob
1 bad 930
Old 06-27-2007, 10:45 AM
