LinkBack Thread Tools Rating: Thread Rating: 1 votes, 3.00 average.
djmcmath's Avatar
Originally posted by Oracle
I ditched wireless, cause everytime the microwave oven was used the connection dropped completely... just plain annoying...
Your MW is emitting enough 2.4GHz radiation to effectively jam other signals in the house, and you ditched the safe piece of gear? The MW should be FCC certified not to emit RF at all, actually. If the MW interferes with the wireless, the MW should be replaced.
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 06-29-2007, 02:46 AM
robs944's Avatar
I agree with djmcmath, try changing your wireless channel from the default. There are 11 channels available for B and G networks, 1,6, or 11 have worked best for me in the past. If you have secured your wireless (no broadcast, wep, etc) then I think you will need to configure your wireless cards for the same channel.
How close is your cordless phone to your router? Try moving one of them if they are too close.
Also if you have a fax line that should proabably have a filter as well.
masraum - The only problem with 802.11a is that is has a shorter range signal and can be easily obstructed. Of course if you live in an apartment or small home this may not be an issue.
Or just wait until 2008 when 802.11n is approved (270 Mbit/s) this may not fix your problem but your LAN will be blazing
Let us know how it goes.
Rob
87 944 * 89 951
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car."
Old 06-29-2007, 06:57 AM
Virginia Rocks!
VaSteve's Avatar
Re: Wireless Router "lost" when using telephone
Originally posted by ikarcuaso
I recently got a new Netgear Wireless-N Gigabit router. Love it, except when we use our telephone that shares the same phone jack, the router "disappears" from my network. It goes away from the list of available wireless networks, and any computer using that connection is disconnected. It comes back when we hang up.
I work @ home and lose my VPN connection with incoming and outgoing calls on that telephone. Obviously not productive.
Anyone experience the same. Never had this problem with my prior router, also a Netgear RangeMax. Any clues to solve this? TIA.
I have the same problem with Belkin(?) router I have had for a couple of years. The issue just started recently oddly enough. I use the speakerphone function when I need the phone. Keeps the calls shorter
I really need to look into the issue.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 06-29-2007, 07:42 AM
User
ikarcuaso's Avatar
Well, I tried an old school corded phone, and that worked, no problem. Plugged the cordless phone back in, scanned for another channel, placed a call...problem solved! Thanks again for all the help.
82 Targa
Old 07-03-2007, 09:53 AM
Ferdinand Magazine
johndglynn's Avatar
Glad your problem is fixed, this sort of thing drives me nuts. I had exactly the same problem a while back, broadband would drop out when you used the phone, then started dropping out for no reason. Dunno how many times I rang the phone company and eventually they agreed to come out to take a look. Something made me take the cover off the wall socket before they came out just to check those wires were OK, and turned out a critter had manged to sneak up into the tiny little junction box and barbeque itself across the contacts. Removed the cremated remains, replaced the box and was all OK again
Sheriff at www.impactbumpers.com
Brand support at classicretrofit.com/tuthillporsche.com
1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles
Old 07-03-2007, 11:49 AM
