<insert witty title here>
Notebook PC crashing - diagnosis?
My wife's notebook is crashing for no apparent reason, and we're a bit baffled by it. Can anyone point us in the right direction, or suggest some tests we could run?
After 20-25 min. the computer suddenly turns off, as if you pulled the battery out. No warnings from windows, nothing. Then if you turn it back on, it seems to last less and less time before it shuts down again. The battery reads at 100% according to windows. She said it feels hot to the touch on the underside (where the fans are) but the fans are indeed working. The lights on the front indicate the AC adaptor is connected. We tried running it with the battery removed and just the power cord connected, but the same thing happened. Thanks! Chris
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
Dept store Quartermaster
Clean the heatsink, lint clogs them. Remove the fan cover and you should see it there.
Cornpoppin' Pony Soldier |
what operating system? what are your power settings? it could have been accidentally set to shut down the hard drive after x number of minutes..
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
If you can't get to the fans, with the laptop off, shoot some canned air from where the air exits. This should push tons of crap out where the fans are. Toshibas are famous for this.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
User
Make/model? Some have notorious design flaws resulting in failures like this (like my Dell 5150). Warranty?
82 Targa |
Hey guys, thanks for the ideas so far. I forgot to mention it's a Toshiba Satellite A70. We got it all apart, and sure enough there was a ton of crap in the heatsinks and fans. Cleaned out, now working on reassembly. (1am, have to work in the morning...)
You took the entire thing apart? And yes, the A70 is notorious for sucking in dust. See if you can get it apart and back together in 45 minutes. That's my record. Well, I did it daily.
Dave
19 years and 17k posts...
Could be hardware-heat related as others have suggested. Have you installed any device drivers lately?
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
