Do I need to add oil to my floor jack?
I've got an Arcan 3.5 ton floor jack. I know some jacks need hydraulic oil added to them periodically but I don't see any place to add oil on mine. Are some jack sealed - no service? It's a Costco special ($99.00) and it's been great otherwise.
Anyone?
Kurt |
Unoffended by naked girls
Is it working ok?
If it's not leaking, you shouldn't need to add oil. It would only lose the very thin film on the ram when it's extended. Seems to me I had one that you added oil where the vent screw was...
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
Thanks for the reply. It seems to have worked fine all along except for once (operater error?), never any leaks.
Kurt |
Senior Member
Kurt,
The time you usually realize that you need fluid is either seeing a leak (and it needs to be fixed) is when you try to lift something and the jack will not go to its full extension. As for refilling it, look to see if there is a cover on the top that you can remove. Most of them have a large slotted screw that you remove to add fluid. Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Detached Member
99 bucks from Costco? I'll bet its a throw away.
Hugh |
