KNS KNS is online now
Do I need to add oil to my floor jack?
I've got an Arcan 3.5 ton floor jack. I know some jacks need hydraulic oil added to them periodically but I don't see any place to add oil on mine. Are some jack sealed - no service? It's a Costco special ($99.00) and it's been great otherwise.
Anyone?
Kurt
Old 08-11-2007, 09:52 AM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Is it working ok?
If it's not leaking, you shouldn't need to add oil. It would only lose the very thin film on the ram when it's extended.
Seems to me I had one that you added oil where the vent screw was...
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 08-11-2007, 09:55 AM
Thanks for the reply. It seems to have worked fine all along except for once (operater error?), never any leaks.
Kurt
Old 08-11-2007, 11:25 AM
Senior Member
Kurt,
The time you usually realize that you need fluid is either seeing a leak (and it needs to be fixed) is when you try to lift something and the jack will not go to its full extension.
As for refilling it, look to see if there is a cover on the top that you can remove. Most of them have a large slotted screw that you remove to add fluid.
Joe
Old 08-11-2007, 12:00 PM
Detached Member
Hugh R's Avatar
99 bucks from Costco? I'll bet its a throw away.
Hugh
Old 08-11-2007, 08:59 PM
