Super Moderator
A failing wheel bearing usually sounds more like a moan.
I'm with Bill
3 cars have bad wheel bearings at the same time?
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
Cars & Coffee Killer
I jacked up the right side of my car, then the left.
I did a "wiggle" test on each of the four wheels. All were tight (no excess play). I don't think it is the wheel bearings. I turned each of the four wheels by hand. The last time I did this, all of the wheel turned freely. The rears turn freely. The front left has constant resistance. The front right has intermittent resistance, corresponding to the same point while turning the wheel each time. I hear a very slow version of the "noise" when doing this. I took out my battery powered impact wrench. I can't budge the lug nuts with the POS. (See my thread on wanting a decent air-powered impact wrench.) I tried a breaker bar, but the wheel just turns while off of the ground and I can't figure a way to "lock" it while jacked up. My theory is that I have a warped right front rotor, and the left caliper is too close to the rotor.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Loosen the lug nuts with the car on the ground.
(we all know not to completely remove them, but just Loosen them, then jack the car up) To re-install: Tighten them as tight as you can while in the air, then set the wheel on the ground, and then torque to spec.
Brent Early85 944 LM6Y Paint Code |
It appears all four calipers are sticking. Joy.
Parrothead member
With a warped rotor, you would feel it in the brake pedal.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
