Calling HVAC experts...
I'm very happy I decided to change my air filter tonight. When I did so, I looked down into the pan surrounding my heater on the floor and there were a few inches of water in there. I'm pretty sure it was dry two weeks ago when I got back from CA and had to fiddle with my heater to get it to come on. I used a sucker piston that I usually use when I overfill a car with oil. I took out nine quarts of water!!!
Last Feb., on about the coldest day when I was home sick, my heater went out. HVAC guy came and fixed it and said it had gone out because that water level had risen to the kill switch. I can't remember if I asked him what causes that. But it would have happened again very soon, had I not discovered all that water tonight. What causes that? I'm guessing condensation. But how can it be so much so fast? I think I'll call them again mid-week and have them come out Thurs. or Fri. when I'm working from home. But is there anything I can DIY here? Furnace is gas, has no pilot light and is about five yrs. old.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Condensation. Isn't there a condensate drain? Plugged up?
Make Bruins Great Again
Condensation comes from running the A/C, not heat. There is suppose to be a drain or an electric pump to get the water out of there.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Unconstitutional Patriot
Is this a 95% efficient furnace? It won't have a gas vent pipe. Those units create condensation from the combustion. If the water cannot gravity drain, it needs a condensate pump. Those pumps can fail. I'm not certain a supply house will sell this part to you.
Platinum Member
Pop the cover and look around, follow the drain lines. At about 5 years old, I replaced most of the clear plastic drains on my furnace. |
I found the drain line and pulled the pvc pipe away to check for blockage. Looked clear to me and the L at the bottom ran downhill. So I poured about 1/3 liter of tap water down it and heard it all rush down and along the long drainl. Pretty sure it ain't clogged. I called the local HVAC place that serviced the unit before and the guy said it had to be from when I had the a/c on. That was a good three weeks ago last and I'm sure the drain pan was bone dry when I checked it after I got back from CA on 10/28. He said there's no way the heater could have produced that condensation and there was no other water source in the unit. I guess I'll just have to keep an eye on it and be sure to have it serviced when a/c season approaches.
Retired Member
Sometimes the condensate trap collects crap that will prevent the condensate to run to the drain. It can back up.That could be the source of the water.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
