BRPORSCHE's Avatar
Send a message via AIM to BRPORSCHE
New DEI system!
check out this genius idea! Haven't laughed like this in a while.
http://www.gmmodernmuscle.com/forums/viewtopic.php?t=2779&postdays=0&postorder=asc&start=0
"First off, Jay, stay out of this.
Ok. I didn't want to mention it but I was thinking about turbo charging my Vette. I got to thinking about it and how in efficient even turbos are (compressor efficiencies of about 80% at best).
Since a turbo's function is to pressurize incoming air and force it into the upper motor, and turbos are driven by high pressure exhaust gas created from the combustion process, couldn't I just bypass the turbo altogether and route my headers back into the throttle bodies?
Since I have CFI, I could balance the DEI (direct exhaust injection as I just coined it) by feeding one header into each throttle body. Yes, the charge air wouldn’t be that cold, but it would be under a hell of a lot more pressure.
I attached a quick sketch below:
There are still a few things I need to work out:
1) How do I get the CFI aircleaner to fit in a way that hides this plumbing?
2) Does anyone make a V-band clamp that will bolt an exhaust header to a CFI throttle body?
3) What pinion angle should I use in my rear-end? I’m sure there will be a noticeable difference in torque output.
What do you guys think?"
-Tom
'73 911T MFI - in process of being restored
'73 911T MFI - bare bones
'87 924S - Keep's the Porsche DNA in my system while the 911 is down.
aka "Wolf boy"
Old 11-16-2007, 04:56 PM
sudo apt-get purge 930
equality72521's Avatar
There is another thread on this one. Radical Innovation: Direct Exhaust Injection (DEI)
--clutch-monkey
Old 11-16-2007, 04:57 PM
