Continental, Lycoming, Corvair and Prosche
Is their a link here? I know Mooney used a Porsche engine on a limited basis, but that's not what I'm talking about.
These engines are all too similar to not be related somehow. Flat opposed, split case, etc. Did they all license from Porsche? Anyone know which evolved first? Wasn't Porsche using its flat engines while the aircraft industry was still using radials and in-lines?
David 1972 911T/S MFI Survivor |
Senior Member
Continental and Lycoming were making both radial and horiz opposed air cooled engines long before Porsche was in business.
That said, the engines are very much alike in many ways and it would not be a stretch to assume that the old man had seen a horiz opposed aircraft engine and decided to incorporate it or its ideas into his cars. The early radial engines were very different in that the entire engine assy turned, not just the crankshaft and the prop was bolted to the engine. Later ones were changed where the engine was bolted to the airframe and only the crankshaft moved the prop. This style of engine was used up until the last prop/piston fighters then started to lose favour to the jet engines.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
![]() ![]() ![]() ![]() All unrelated???
Sultan of Sawzall
...and many companies build V8's as well. Just a good, basic design.
![]() and don't forget, Chevrolet did the 6cyl. a few years ahead of Porsche.
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
Sultan of Sawzall
Bill is Dead.
Some early engines, such as the Continental A-40, did not have a split case.
Continental engines were also used in tanks and cars - such as checker cabs. The radials in which the engine turned were called rotary radials. They produced almost unmanageable amounts of what you would know as torque-steer. Some companies today still produce aircraft using fixed radial engines.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
The Tucker, in 1948, had a flat 6 air-cooled Franklin helicopter engine that was converted to water cooling.
Continental A-40, 1931.
VW beetle dates from late '30s.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Bill is Dead.
I was pointing out that not all boxer type engines have a split case.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
It's all about knowing where to look...
Senior Member
Interesting tidbit of information... what is used to seal the two cases together on early four banger Continental aircraft engines? s c r o l l d o w n f o r t h e a n s w e r A very fine silk thread is used between the two case halves to seal them. No sealant, gasket or the like is used, just the thread. Do not know of any other engine in the world that uses this method.
MAGA
I use the double strand of silk thread on Lycoming also with a very light film of sealant to hold it in place.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Banned
The reason for the horizontally-opposed engine? It allows better air-cooling without increasing frontal area drastically. This is why the majority of aircraft flat engines use a pushrod valve train- it interferes less with cooling air flow. The 911 motor with its' SOHC heads and cam chains works because it has a cooling air fan, something that aircraft engineers want to avoid.
Radials are very light for their power, and quite rugged, but they have enormous frontal area. The V-12 engines used in WWII fighters were superior from an aerodynamic standpoint, but they were heavy and they had the "achilles heel" of liquid cooling. |
abit off center
This is one sweet set up! Note the twin mags running right off the cams.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
_ |imothy Farrar '69 911E +webers +906 cams -- in peaces S-10 +straight-cut gears +LSD -- daily driver WRX -- wife's car |
FYI: BOXER ENGINES
http://www.flydiver.com/ This one is cool. VM125T 78HP DUAL CARB COG BELT 4 STROKE RELIABILITY AT 2 STOKE PRICES!
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
