FTP server question
I run a ftp server from my home computer.
XP Pro Serv-U Netgear router Dyndns.org account Dynamic ip thru at&t with the updating being done by the netgear router Today when I check the server using Smartftp from my work computer (not part of the home network) I get the 'server has actively refused the connection' error. Server log shows me as logged in successfully. If I do nothing for a minute or so, the ftp client refreshes and the connection goes thru successfully and all is well. If I disconnect and reconnect the same thing happens. The client is getting hung up on the list directory command, after it refreshes and tries again it lists the dir. Another client I tried simply stops at the list dir command and does nothing. Any ideas? |
Has it done this before?
Did you upgrade any software or firmware? Know of any configuration changes to your work network? Could be a lot of things. |
I have been making network changes to get my Vista and XP computers networked. Finally got everything working properly and then the ftp server did not work smoothly.
I just figured it out. I do not allow passive transfers and all is well. Learn something new everyday. Thanks for the response |
| All times are GMT -8. The time now is 02:56 AM. |
