FTP server question
I run a ftp server from my home computer.
XP Pro
Serv-U
Netgear router
Dyndns.org account
Dynamic ip thru at&t with the updating being done by the netgear router
Today when I check the server using Smartftp from my work computer (not part of the home network) I get the 'server has actively refused the connection' error. Server log shows me as logged in successfully. If I do nothing for a minute or so, the ftp client refreshes and the connection goes thru successfully and all is well. If I disconnect and reconnect the same thing happens.
The client is getting hung up on the list directory command, after it refreshes and tries again it lists the dir.
Another client I tried simply stops at the list dir command and does nothing.
Any ideas?
Randy
'87 911 Targa
'17 Macan GTS
Old 12-11-2007, 10:13 AM
The Unsettler
stomachmonkey's Avatar
Has it done this before?
Did you upgrade any software or firmware?
Know of any configuration changes to your work network?
Could be a lot of things.
"I want my two dollars"
"Brandon Won"
Old 12-11-2007, 10:28 AM
I have been making network changes to get my Vista and XP computers networked. Finally got everything working properly and then the ftp server did not work smoothly.
I just figured it out. I do not allow passive transfers and all is well.
Learn something new everyday.
Thanks for the response
Randy
'87 911 Targa
'17 Macan GTS
Old 12-11-2007, 10:36 AM
