Because otherwise you Americans would fall off.
I've often wondered why the equator wasn't verticle :) http://forums.pelicanparts.com/uploa...1200319521.jpg
This one is for the Neocons (it'll kill 'em being on the left):http://forums.pelicanparts.com/uploa...1200319652.jpg
Isn't the earth a little wider at the Equator because of the centrifugal force of the spinning? Regarding the "north-cerntric" view...Can't that be determined by relation to other planets and the sun? (Assuming those aren't upside down as well). Regarding maps....I did some driving in Europe. All the maps have the "local names" for the cities...it was brilliant! :D |
comparison of land area by country
http://en.wikipedia.org/wiki/List_of_countries_and_outlying_territories_by_area |
Why is a turd tapered at the end?
So your butthole doesn't slam shut.
The top picture is the correct orientation, for now. After december 21st 2012, the second picture will be right ;)
Every map contains a compass rose with the map oriented in the direction the little magnetic needle first pointed. http://forums.pelicanparts.com/uploa...1200333409.jpg |
OK, so when I am going north in my suv, the little compass says N in the mirror, now I stop and start backing up, it still says N not S? Why? Is it because I have to poop?
Always assumed that it's because over 80% of the land mass on earth is North of the equator.
My vote as well. Lines of magnetic field and all.... |
| All times are GMT -8. The time now is 04:49 AM. |
