abit off center
cgarr's Avatar
Ink Jet refills
Anyone refilling their own ink jets? I got a free cannon printer with my laptop MP-160 and just tried the refill kit, it was about 20 bucks for both color and black and refills 3 times. So far so good. The Kids can print again all they want now..
______________________
Craig
G2Performance
Old 01-19-2008, 11:49 AM
Make Bruins Great Again
Por_sha911's Avatar
I've done refilling HP cartridges for about 12 years and it works great. The main things to remember are: make sure you follow the instructions exactly and, you should let the cartridge sit a while to make sure it isn't leaking. Eventually you will have to replace the cartridge but you still save a ton if you can get an extra 2-3 fills (especially with the tri-color cartridges where only one color runs out).
Joe
Old 01-19-2008, 12:10 PM
DP935 member
kycarguy 935's Avatar
We have a place here that refills your cartridge. They charge $16.00 per unit. It's not as cheap as doing yourself though.
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 01-19-2008, 01:07 PM
HarryD's Avatar
About the only issue I have with refilling is that the little holes that spray the ink onto the paper get bigger as they age and eventually the ink is too blobby. I find 2-3 refills is all that I can stand before the results are not acceptable anymore.
For this reason alone, I do not want to go with one of the servies that sells refilled ones since you do not know how many times a cartridge has been reused.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-19-2008, 02:00 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
I try and print everything either at school or at work. This way my ink cartridges at home last quite a long time
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 01-19-2008, 04:51 PM
walgreen's by us charges 5 bucks per catridge.. worth it so far
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 01-19-2008, 06:04 PM
