JW Apostate
trekkor's Avatar
When to use 91 octane fuel?
AKI or RON?
320i manual says 87 ( with anti knock index ) or 91 ( research octane number ).
What's the way to go?
It's my nephew's car and it seems to be running a little hot.
He uses 87.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 01-22-2008, 07:26 PM
Detached Member
Hugh R's Avatar
Most gas in the US is sold as an average of the two. Try 89
Hugh
Old 01-22-2008, 08:05 PM
AKI is the average of RON and MON. You can usually assume AKI to be around 4 points lower than RON (although this is not strictly true, it's close enough) so he should be safe with 87, if the car is healthy. 89 is cheap insurance if the car has some miles on it and may not be in perfect tune. The hot running is probably the radiator. If it hasn't had a steady diet of coolant changes using BMW's coolant, or the equivalent, I'd say just put a radiator in it. You didn't say what year his car was made. Some genertions of BMW's use a lot of plastic in their radiators and most of us BMW nuts consider those to be past their useful life after 60k miles. Failures at the upper hose neck are common.
JR
Old 01-23-2008, 05:17 AM
JW Apostate
trekkor's Avatar
Thanks.
It's an '83 with 200k+ miles on it.
KT
'01 Boxster
Old 01-23-2008, 10:23 AM
