Me like track days
I want to melt 1/2 oz of gold leaf.....
Best method? Melting temp and way to melt w/o blowing it all over? Suggestions welcomed !
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
It's probably not pure gold. Gold leaf, often is mixed with silver or copper, depending on the color.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Senior Member
Why?
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
I've sent bunches off to the melters but haven't tried it myself. Temp will need to be 1500-2000 F, depending on the alloy. An electric furnace would be best and some sort of ceramic crucible to hold the AU. A torch might be tough to control the temperature.
Jim
down to jap bikes that run and a dead Norton |
Free minder
Wouldn't the gold leaf (assuming the sheets are usable as that product and not "scraps") be worth much more in that state than melted down?
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Me like track days
They are small pieces, light as a feather.
Is there a torch you'd recommend for heating a crucible? Something to add to the gold so it won't stick, or ? All ideas welcomed, thanks in advance!
FUSHIGI
Don't put it in a brass freeze plug and heat it w/ a torch. Such was the fate of my father's H.S. class ring...by his own hand...reportedly turned into a chunk of "slag" that was pitched...brilliant
DP935 member
Brass melts at 1652-1724 degrees and gold melts at 1946 degrees fahrenheit.
Porsche Slantnose M505 M506 group on Facebook. https://www.facebook.com/groups/719995181372494/ |
Re the class ring melted with the brass, it would still have scrap value, the karet %age would be considerably lowered.
Reminded me of a customer who was going to fix his wife's broken gold bracelett with his arc welder. fffffffffffft, vaporized. Jim
When you melt down gold and after it is melted doesn't it become pure gold? By melting the gold it burns up all the impurities in it, right? Like for instance, if you melt down different types of karats of gold into one melting pot then doesn't it all merge together burning out the all the impurities that each gold piece had making it one pure gold piece? I don't know, just asking so I do know.
No, you just change the shape. I've sent a lot off to the smelters but haven't made a study of how it's done. There's some time and expense involved. That's why Kitco only pays $1365/oz for 24kt scrap when gold is $1500/oz.
Jim
ship it up here - I'll melt it for you
can't afford DSG |
Wad the leaf up into a ball and beat it with a hammer. I bet you end up with a BB size of gold.
1966 - 912 - SOLD
Fire brick
Propane torch Borax powdered soap- Place the small pile of "gold" on the brick as condensed as possible. Shake some borax on top. It acts as a flux and will help keep the metal clean and together. Gently aply heat melting the flux then the metal. Be gentle with the torch- |
I don't mean to get all philosophical, but the answer to a lot of life's complicated problems is to beat that crap out of something with a hammer.
Ok - so what about things like the pins on older cpus? I've got a bunch of 'em, need a good way to remove pins from the die, etc. Snipping leaves too much on and sends too much flying.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
White and Nerdy
Shadilay. |
Banned
micro thin plated
there might be a ounce in a ton of pins only worth doing with china rate labor and no EPA and tons of CPUs to deplate |
