Banned
Table saw or band saw?
I need to mill my own trim pieces to finish off a laundry room I am working on. I had intended on getting a cheap table saw and putting a finishing blade in it.
But I noticed that the band saws also have a reasonable large surface to work on, and an adjustable guide as well. I don't need to rip plywood, just trim pieces under 8 inches.
Any thoughts on this? Will I be able to cleanly split trim pieces with a band saw? Or will it be to squirrelly?
Any guidance appreciated.
Old 02-17-2008, 11:21 AM
Wood Magician
Definitely a table saw, It's much more accurate for what you are intending to do. A band saw is for cutting curves and re-sawing lumber so by design it is not as accurate as the table saw or as versatile a machine for the once in a while wood worker.
Old 02-17-2008, 11:50 AM
s_wilwerding's Avatar
Why not a chop saw/power miter saw? They are generally more usable than either a tablesaw or bandsaw, and take up a lot less room. They work perfectly well for the making trim cuts, though some may argue that a table saw is a little more precise. But unless you're building finish cabinetry, the miter saw would probably be fine.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 02-17-2008, 11:51 AM
Wood Magician
Oh and as your pieces are under 8" I would build a little jig to hold the piece as it is pushed through the table saw, a lot safer that way. Simply a piece of plywood about 6 inches wide and 18" long with the long side going against the fence of the saw and some smaller pieces of wood tacked to it's surface to provide a holding fixture for the trim pieces you will be cutting.
Old 02-17-2008, 11:55 AM
AutoBahned
RWebb's Avatar
look like the clincher here is that you want to 'split' the wood - i.e you have some special wood you want to use and you want to cut it in 1/2 or more in terms of thickness?? is that right?
otherwise you just 'need' a chop saw -- or an angle guide and a hand saw...
There is a book on simple band saw usage but it points out the versatility of the things in the Time-Life series "Art of Woodworking."
I usually think of them for finer work.
Also, depending on how fine - one of the woodworker catalogs now has a complete trim 'kit' available with a fancy sanding disc for $600 or something -- looks like you do things to the precision of a machinist with it - think it was that Canadian company - sorry cannot recall name.
Maybe milt will chime in...
also...
http://www.cs.cmu.edu/~alf/en/en.html
Old 02-17-2008, 11:58 AM
Wood Magician
I interpreted the question as needing to do a rip cut on the 8" trim pieces but if its a cross cut then a chop saw would be much better as others have mentioned.
Old 02-17-2008, 12:02 PM
Proprietoristicly Refined
John_AZ's Avatar
HardDrive,
I use a standard table saw-10 inch. I have blades to mill/mold stock-Craftsman-3 blades screwed on the holder. Many different styles of cuts. I have done a lot of interior trim and exterior work like custom veranda railing.
This is a basic as it gets.
Available on Ebay as well.
Caution: Any molding device is dangerous. The wood will grab, fly, tear.
Wear all protection and maybe steel mesh gloves or this will happen:
Molding devices are among the No.1 hospital emergency room woodworking accidents. The two stubs on the left are mine.
John_AZ
Old 02-17-2008, 12:18 PM
Banned
Thanks guys.
I guess I wasn't being clear. I have a chop saw for creating miter cuts.
I need to take long strips of trim, and shave off part to get the correct width. So for example, I have a 3" piece of trim, but I need to be 2.25" wide.
Sounds like table saw is the way to go.
Old 02-17-2008, 01:53 PM
Banned
gassy's Avatar
Send a message via ICQ to gassy Send a message via AIM to gassy Send a message via Yahoo to gassy Send a message via Skype™ to gassy
Definitely in that case. John, I have a stub--from a table saw tho!
Old 02-17-2008, 01:58 PM
Wood Magician
Yes, definitely a table saw- Enjoy the project!
Old 02-17-2008, 02:05 PM
slodave's Avatar
Buy a Sawstop. It'll give you a better chance at saving your digits. I would use (and have) a bandsaw for what you want to do.
http://www.sawstop.com/
Old 02-17-2008, 02:10 PM
coulda, woulda, shoulda
johnco's Avatar
was a finish carpenter for 12-15 years. I've been thru at least 4 table saws. wore them out. about the only thing I can remember using my bandsaw for in all that time was cutting some swing parts and some pvc pipe I needed to use as a drain under a pool. get the table saw, unless you do arts and crafts to sell at a fleamarkets, the band saw will just be taking up space. I've got 2 of them pushed aside collecting rust and dust. come to think about.. so are 3 table saws, 6" table sander, routers... a truck load of woodworking tools. carpentry work sort of got pushed aside for pool work.
John
74 911s
Old 02-17-2008, 02:44 PM
slodave's Avatar
To each their own. It's easier for me to go to the band saw, flip up the bar to tension the belt and make a few cuts.
The real question is.... Are you planning to use the item after this project?
Old 02-17-2008, 02:49 PM
WI wide body's Avatar
For what it sounds to me like you want to do there is little doubt that a table saw would work better. Make a fixture of some type and it will be an easy job on a table saw.
Old 02-17-2008, 02:55 PM
Targa, Panamera Turbo
M.D. Holloway's Avatar
That hot dog demo is pretty incredible. I gotta say, I would like to see that demo in person - if I spent any kinda time on a table saw I would buy this thing without hesitation.
Michael D. Holloway
https://5thorderindustry.com/
Old 02-17-2008, 07:52 PM
Canadian Member
911Rob's Avatar
Tablesaw for sure.
How about dropping the pieces at your supply store or a millshop?
My supply store would do this for free and a millshop would be cheap.
No worries, job done
Rob McKibbon
Arena Red 96 993 TT LINK
Contemplate YOUR Success!
Old 02-17-2008, 08:02 PM
slodave's Avatar
We have one. No, we have not tried the hot dog demo, as it'll destroy a blade and the expensive cartridge that stops the blade. I will take pics of the workshop I have access to.
The SawStop is a great table saw. We sold our perfectly working Delta for it.
Dave
Old 02-17-2008, 09:43 PM
don911's Avatar
I have a Bosch table saw that is portable with a colapsable stand.
I bought it for the exact same purpose but was trimming a large house. You're welcome to borrow it if you want.
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
Old 02-17-2008, 11:14 PM
