restored laptop to original configuration..problems..
it's a dell inspiron 9300. first thing i did was organize data folders with family pics, documents, etc. that i didn't wanna lose and cut to a portable hard drive. then i forgot until it was too late, after doing a F11 command and making it restore itself to the original point when i bought it (remanufactured)..prompting me for country, language, time-zone, etc. in doing so, i lost all of my installed programs that i did myself, as well as forgetting to move about 500 songs i'd downloaded over two years...ouch! don't guess there's anything i can do about losing them as well as all my bookmarks..forgot to save that file as well (it was the middle of thenight and i should have left it well enough alone).
other problem is that my dvd+rw drive won't play. it lights up, makes sounds here and there, but never gets to spinning up. right-clicking the drive and checking the device, it says it's working properly. the laptop did suffer a little fall a few months back..could it have just loosened a cable inside? if so, is the drive easily removed or is time for the 'geek squad'? i've taken apart and re-worked a few desktops in my day, but never messed inside of a laptop. any advice? thanks! ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
holy cow...windows media player just did 'do you want to look for more music files' question during new configuration and found my 580 songs!
well, that part's a huge relief!
spoke too soon..
only found some, maybe 50. i think most of it was in the 'shared folder' under doc's and settings that was cleared out when i forgot to move those files to the portable drive during the reset. crud..
The Unsettler
is the dvd a dual cd/dvd device?
they have 2 lasers, one for cd, one for dvd. sometimes one laser fails and not the other, try various media
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
thanks. yes, it will operate both. just checked..it will play a dvd, but won't recognize a blank or installation cd...
There usually is only one laser that adjusts its height and intensity. Having taken many apart for the laser and rotor, I have never found two.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Senior Member
Check the recycle bin, might be some files in there that you want to restore.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
The Unsettler
Don't remember the specific model number/manufacturer.
But did you actually tear down the drive? I have two in front of me and they are both one laser.
The Unsettler
Just because you have not seen one yet does not mean it is not true.
You can take a laser out of an optical drive and in about half an hour, create a little laser pointer that will actually cause a match to combust or pop balloons
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
none, joe..setting the system back to original configuration wiped a lot out.
it's a sony dvd+rw DW-Q58A......?
Every now and then, a low level driver in Windows corrupts and you have to go into the registry remove the entry and reboot. Windows will rebuild the registry key and your drive may work.
These are the two registry keys you need to find and remove.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}\LowerFilters HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}\UpperFilters
will report shortly..
found the registry keys, but not where it says \lower filters or upper filters?
nope, found a line that says lower filters, but not higher....should i go ahead and delete the lower filters line?
Here's a screen shot:
![]() If the upperfilters line does not exist, don't delete it ![]() Delete the lowerfilters, close regedit, reboot and see what happens.
