Send a message via AIM to SlowToady
OBDII code on 01' VW Golf
I've been having a bit of car trouble lately, and am wondering if someone can help me figure out what this code means. I believe it was P00332 and it said something along the lines of "Ignition/Engine Transition Circuit" --I'm trying to remember from last night, so that might not be exactly right.
2001 VW Golf 2.0
The problem I'm having is that it doesn't like to start when the engine is hot. For example, if I drive it around, get the engine to operating temperature, shut it off, and try to turn it on like 2 minutes later, it won't go. I have to let it cool down before it will start. Sometimes is has to be COMPLETELY cold before it will start, sometimes only half cold or so. When it first started happening, I could usually coax it into starting if I depressed the gas pedal all the way when trying to start it. Doesn't work anymore.
Any ideas on what that code means, or what I might check into to fix or diagnose it? I'm a college student, I definitely can't afford to take it to the VW dealer and just say "fix it." Heck, they wanted $100 just to hook it up to their machine and diagnose the error code!
I've been hearing that 01 and up aren't really good years for VW electrical systems...at 85,000 mi. I think I might be about to experience those gremlins.
Thanks,
~Slow
I turn away with fear and horror from this lamentable sore of continuous functions without derivatives. --Charles Hermite
Fakelife.com Nothing to do with archery anymore. Porsche/BMW/Ferrari/Honda videos
Old 02-16-2008, 12:56 PM
is this thing on?
NICKG's Avatar
you have a bad coil..the final stage is going bad...
Old 02-16-2008, 04:58 PM
Seriously, ignition coil? Wouldn't that just fail all at once though? Is there a test procedure for it? Anything else it could be??
Thanks Nick!
Old 02-16-2008, 08:26 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
if it's like my audi it doesn't have an ignition coil rather seperate coil packs so I doubt the diagnosis..
Go out and get yourself an ODBII reader , will pay for itself ..
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 02-16-2008, 09:43 PM
01' still has spark plugs, no coil packs. I do remember them giving my brother a bit of hell in a GTI he had though:-P
Definitely considering buying an OBBII scanner.
Old 02-16-2008, 09:58 PM
9dreizig's Avatar
the packs sit on the plugs.. my 01 audi is the same engine . I still doubt it's the coil even if it had one.
"Todd"
Old 02-16-2008, 10:04 PM
Yep, like most everything else, I did a horrible job of explaining what I meant to say:-D The 01 has no coil separate coil packs though.
Heck, I'm almost surprised mine doesn't, though. Brakes are from an 02...seems to be a late 01 build that got some 02 parts..?
Ohhh VW...heh
edit:
Are you sure it's the 2.0L? I thought the A4 was either the 1.8T or the 2.8 six?
Old 02-16-2008, 10:07 PM
9dreizig's Avatar
Correct, mine is a 1.8 L turbo.. Question does this usually happen in the summer ? I'm thinking maybe vapor lock ?
T
"Todd"
Old 02-16-2008, 10:37 PM
I wouldn't know, it's only been doing it for a few weeks (2, maybe?). It's still winter down here in Kentucky.
T
Old 02-16-2008, 10:55 PM
peppy's Avatar
slowtoady I could not find code P00332. I did find code P0332 Knock Sensor 2 Circ Low Input.
Here is a list of codes http://www.bentleypublishers.com/tech/vw/vw.dtc.table.htm
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 02-17-2008, 12:42 PM
djmcmath's Avatar
If it has individual coil packs on each plug, then a failure in a single coil pack would cause a misfire, rather than a difficulty in starting. If a knock sensor was failing, it could cause the computer to slowly set the ignition timing farther and farther out until it just didn't work any more. That's just me spit-wadding, can anyone validate the theory?
Dan
'86 911 (RIP March '05)
'17 Subaru CrossTrek
'99 911 (Adopt an unloved 996 from your local shelter today!)
Old 02-17-2008, 01:11 PM
Peppy, you're right, that should have been P0332. I can't seem to get anything right on this post:-P
Knock sensor huh, that's cool...Is it possible, though, that the knock sensor only goes wonky when the engine is warm? My starting problems *only* occur when the engine is warm, never when it's cold.
Thanks guys, I appreciate it!
Old 02-17-2008, 01:31 PM
is this thing on?
NICKG's Avatar
the coil is bad...btdt
Old 02-17-2008, 06:17 PM
sudo apt-get purge 930
equality72521's Avatar
Spray water from a water bottle on your coil pack at night and see if there are any arcs. The coil packs are notorious for going bad on the MK4 VWs. If you see arcs remove the coil pack and dry it out. Fill all cracks with JB weld. It's a common fix for these.
--clutch-monkey
Old 02-17-2008, 06:24 PM
Tonight, about 30 minutes ago, the engine just shut off sitting at a stop light, then wouldn't restart. 10 minutes, maybe 15, later, it started. Managed to limp it back to campus.
Another vote for the coil, then? I guess I'll be buying one this week....
Old 02-23-2008, 04:42 PM
