imaircooled's Avatar
My Maytag Dryer has quit...can anyone help?
We have a Maytag Performa dryer that is about 7 years old. We've had no problems with it until now. It has quit working. Yes, it's plugged in and yes the door is shut. I went to the fuse box and nothing was flipped. I checked the power cord and everything looks good and nothing was loose. I took the back off of the controls and everything looked good there too. The dryer has a light inside that comes on when the door is open. That light no longer comes on so, it seems like it's not getting any power. I'm alright mechanically and hope that it's something small or something that has vibrated loose. Does anyone have any ideas?
Thanks for your help,
Chris
Chris
1974 Porsche 911 Targa w/935 flat fan twin turbo motor, not really
"DTW" Dave W. "There is really not any such thing as a rebuild 'on the cheap' on a 2.7 motor. You'll either pay now, or you'll pay later, but you'll pay."
Old 03-08-2008, 07:03 PM
old man neri's Avatar
Call the maytag man!
Jokes aside try to dig up your manual. There may be a fuse somewhere on the unit.
Old 03-08-2008, 07:08 PM
Registered Abuser
MT930's Avatar
I would look for anything loose. There are a few switches that will cut power if any of the panels are off,(safety type), I would check those first. I just went through a front load washer issue couple months back. There could be a internal breaker or fuse. I found some tips to look for by goggling the model and appliance web sites. Good luck!
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 03-08-2008, 07:12 PM
robmog's Avatar
i learn new things here every day.
exactly where is the "maytag dryer" located.
and more importantly, what does it do?
or why must my maytag be dried?
i can't find it in the workshop manual,
does it go by a different name in a long hood?
bob
1972 E pos
correction: expensive pos
someday....
"shut up and drive!"
Old 03-08-2008, 07:32 PM
Thanks guys for responding quickly. I'm searching the internet for a possible fuse that may be blown.....but I may have to call the Maytag Man!!!
Rob,
1. in my house
2. dry clothes
3. because it is wet
4. not in your manual....because it goes by a different name on a longhood.
Thanks again,
Chris
Chris
Old 03-08-2008, 07:37 PM
Just realized (with a little help) thank you very much....that I posted this to the technical forum...how do I post to the OT forum?
Chris
Chris
Old 03-08-2008, 07:47 PM
slodave's Avatar
Is it a long or short hood?
Old 03-08-2008, 08:00 PM
gungadin's Avatar
Spill your guts Chris,,
You put the sheepskin seatcovers in there didn't you.
Or was it your floor mats?
She's making you ask us what to do isn't she?......
'76 911S w/ '79 3.0 SC engine. Irish Green
gestalt1's Avatar
just keep in mind that fuses don't just blow all by themselves. there could be short in the heater or possibly the brushes in the electric motor are worn. both of these would cause the dryer to draw to much current and blow a fuse. as a "while your in there" you should consider upgrading to an 11 blade fan.
BMW 128i
73 rsr clone - sold
68 912 project to become 911r (almost done!)
Old 03-08-2008, 08:08 PM
another round please
strupgolf's Avatar
Dont call the Maytag man, he died too.
Getting old is not for wimps.
Old 03-08-2008, 08:09 PM
check out these two links
http://www.applianceaid.com/
http://a-1appliance.com/
I've used both to assist with troubleshooting and have purchased parts from the second a handful of times over the last 8-10 years.
Old 03-08-2008, 08:11 PM
Detached Member
Hugh R's Avatar
applianceguru.com is your friend. You can join for $5/lifetime and ask questions or search for free. They solved my dishwasher not draining problem with one posting.
Hugh
Old 03-08-2008, 08:18 PM
Evolved
Mo_Gearhead's Avatar
There are "fuses" that mount on the air discharge duct and on the metal shroud surrounding the heater element that 'open' when they overheat. Mine are a sort of plastic/oval shape with two wires exiting them.
If the discharge pipe/duct is clogged (not sufficient air flow) they overheat and open. They then must be replaced (easy fix). Less that $10 ea.
Check them with a ohm meter.
Access is by removing the FRONT, (2 screws at bottom/front panel)
Keep the discharge pipe/vent CLEAN!
_______________________
EDIT: While in there, check the door switch; if it fails, it assumes the door is open and will not let the dryer start.
Don't fear the reaper.
Old 03-09-2008, 06:41 AM
Senior Member
Excellent resource!
Old 03-09-2008, 06:45 AM
3.2 CAB's Avatar
Those little things that MO is talking about are the thermo safety switches. Generally when they go bad, you get no heat, everything else pretty much works the same, you just get wet clothes. Is this a gas or an electric model? I have one of the Maytag dryers that has the electronic programing panel. I can't remember the model name, and mine is a gas dyrer. Have you checked the light bulb to see if it is good or has burnt out? What type of controls do you have on your dryer? Knobs or touch panel programing?
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-09-2008, 11:51 AM
greglepore's Avatar
strongly suspect the belt is broken, and the light has been burned out for a while. Search for maytag belt replacement on google. you can pull the whole thing apart in about 45 minutes. The dryer is very simple, and the motor is quiet enough that you likely won't hear it without the belt.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 03-09-2008, 12:25 PM
Thanks guys for the information and the internet sites. My dryer is electric and it has knobs for the controls. I looked up Thermal fuses and think I found mine. I've attached a picture of it below.
Sorry, it's a cell phone picture.
Thanks again for the humor and help,
Chris
p.s. I do not own sheep skin seat covers...............anymore
Chris
Old 03-09-2008, 07:57 PM
I forgot to add the part number of the picture below is: 312916.
Thanks again,
Chris
Chris
Old 03-09-2008, 07:58 PM
I'm a Country Member
imaircooled 2
Stuart
To know what is the right thing to do and not do it is the greatest cowardice.
Old 03-09-2008, 08:04 PM
I have a Maytag that did the same thing. It was a thermal fuse in the back somewhere. It did nothing till the fuse was changed. It looked something like the one you have pictured.
I wimped out and had a repairman fix it.
2000 Boxster S (gone)
1972 911s Targa (sold)
1971 911t coupe roller (sold)
1973 911t coupe / 3.2 (sold)
Gruppe B #057
Old 03-09-2008, 08:07 PM
