Problem with Ignition Coil on Nissan
My dauhgters 2001 Nissan with 1.8 Liter started running very poorly. I pulled the spark plugs and noted the #1 cylinder was not fireing. Replaced the ignition coil and the car ran great for an hour before the same condition returned. Pulled the igntion coil and it looks to be fried.
Took the car to the stealer for a diagnosis but, they could not run it because the ECM was bad. But, they also said the ECM was not causing the coil problem. Stealer wanted $1000 for the ECM and replacement coil. Any thoughts on what might be causing the coil to go bad? Thanks.
Walt 82SC 3.0 81SC 3.6 |
Still Doin Time
Check the secondary ignition for high resistance. IE: worn distributor cap and rotor, wires. If the secondary resistance is very high the coil will be at max output all the time using all of it's energy which in turn will cause it to overheat and fail.
I would be wary of a faulty DME for this issue unless the dealer can absolutely prove this is the root cause.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Still Doin Time
Again they would have to prove beyond a doubt..........
Did you get the memo?
Is the battery good? I had intermittent misfires on my wife's Cadillac SRX with coil packs. Replaced all spark plugs and coil pack in question, still had a misfire and CEL at WOT. Battery had been weak the entire time, finally died. Now with a replacement battery, there's no more issue. Just a suggestion, I know the battery never crossed my mind as the issue.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
