-   -   WOW I own a flex fuel car didnt know it (http://forums.pelicanparts.com/off-topic-discussions/404213-wow-i-own-flex-fuel-car-didnt-know.html)
rick-l 04-16-2008 07:45 PM
Originally Posted by TheMentat (Post 3890411)
Huh???
If you add 10% ethanol, and your car has to burn 10% more fuel, doesn't that suggest that the ethanol produces approximately ZERO energy?
Someone's calculations are off by alot...
Are you arguing how the sentence is worded? I would take 10% ethanol added to mean it was 10% ethanol 90% gas. For ten gallons you would have 1 gallon of ethanol and 9 gallons of gas.
If that is not the case how do you calculate this? With gas I get 25 MPG so 10 gallons of gas I can go 250 miles. With 10% ethanol it takes 11 gallons to go 250 miles (10% more fuel). The 25 mpg is now 22.7 or 10% less.
red-beard 04-16-2008 08:50 PM
BTU content of dry ethanol is aproximately 75% of that of Gasoline for the same volume. BUT, alcohol is also hygroscopic. So the BTU content can actually be quite a bit less, by the time it used. Regular Gasoline these days is supposed to be 90% gasoline, 10% Ethanol. It might actually be 85% gasoline, 10% ethanol, 5% water.
E85 can be far far worse. It is supposed to be 85% ethanol, 15% gasoline. It might be 30% water.
And the taxes are based on gallons, not BTU content. So, yep, you get double screwed.
Welcome to how our government screws things up.
TheMentat 04-16-2008 10:03 PM
What I'm trying to say, is that, you would only get a 10% decrease in mileage if the ethanol in your example had zero BTU content...
using a 75% equivalence to gasoline, and assuming that BTU content is directly related to fuel efficiency, a 10% blend would only decrease mileage by 10% x 25% = 2.5%, yielding 24.375 MPG
That is alot less than the 10% claim from masrum, hence my confusion...
onewhippedpuppy 04-17-2008 05:47 AM
I knew someone whould chime in with a nice ME thermodynamics answer, thanks Red Beard! Thermodynamics..........*shudder*.
