-   -   2007 Toyota RAV4 how to reset maint. required light? (http://forums.pelicanparts.com/off-topic-discussions/406066-2007-toyota-rav4-how-reset-maint-required-light.html)
rfuerst911sc 04-26-2008 01:48 PM
I have a 2007 Toyota RAV4 with a 3.5 V6 and recently when I hit 5,000 miles the " maint. required " light came on. I assume this came on because a oil and filter change is due. So today I did a oil and filter change and tried to reset the light. In the past on previous Toyotas I would make sure the electronic odometer/trip meter was set to odometer, turn off ignition, press odometer stalk, turn on ignition, hold for about 5 seconds and the light would go off. Today no matter what I tried I couldn't get the light to go off. So the question is how do you reset the light on this car?
VincentVega 04-26-2008 01:56 PM
http://www.wanderings.net/notebook/Main/HowToTurnOffMAINTREQDLightOnToyotaSienna
put LCD on trip A; Push and hold the button to turn on the ignition key without starting.
rfuerst911sc 04-26-2008 03:11 PM
Chris you are the man:D The procedure worked perfect and the light is reset. Thank youSmileWavy
