rfuerst911sc's Avatar
2007 Toyota RAV4 how to reset maint. required light?
I have a 2007 Toyota RAV4 with a 3.5 V6 and recently when I hit 5,000 miles the " maint. required " light came on. I assume this came on because a oil and filter change is due. So today I did a oil and filter change and tried to reset the light. In the past on previous Toyotas I would make sure the electronic odometer/trip meter was set to odometer, turn off ignition, press odometer stalk, turn on ignition, hold for about 5 seconds and the light would go off. Today no matter what I tried I couldn't get the light to go off. So the question is how do you reset the light on this car?
Old 04-26-2008, 01:48 PM
VincentVega's Avatar
http://www.wanderings.net/notebook/Main/HowToTurnOffMAINTREQDLightOnToyotaSienna
put LCD on trip A; Push and hold the button to turn on the ignition key without starting.
Old 04-26-2008, 01:56 PM
Chris you are the man The procedure worked perfect and the light is reset. Thank you
Old 04-26-2008, 03:11 PM
