MAGA
Ha, you found me over there. ![]() ![]()
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Tim, that's gorgeous! you are making 2, right?
Tru6 Restoration & Design |
MAGA
I hate welding thin aluminum.... but so far so good.
Tim,
Those fabbed parts look bad-ass--you ahve quite the talent. Looking forward to seeing the completed cafe!
Eric 83 911SC/83 944 bunch of Honda 750s 69 Chevrolet C-20 Longhorn (family heirloom) |
Tim, you are one of the most talented I know. exquisite work!
warning - understatement follows: " but so far so good."
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
Friend of Warren
Tim, here is a friends Triumph Bonneville T120 that he has been doing a bit of fabrication on.
Kurt V No more Porsches, but a revolving number of motorcycles. |
MAGA
Spent a little time this weekend on narrowing up the tank in the knee area. I did it to my heavily bondo'd/cobbed spare tank that came with the parts bike in case I screw it up. I was able to retain the welded fittings, yet still narrow it up nicely, my knees fit perfectly now. As a bonus, having cut the sides off, I was able to get my dollies into the tank and hammer out the dents that had been bondo. Even though the metal was very thin, the carefully fitted new panels welded in nicely.
again, beautiful work Tim!
Autobahn Garage
Tim, If you are going to work on motorcycles you need to gain about 75lb's, Grow some facial hair, Get a bad attitude, and throw tools and kick down doors. That's how the guy's at OCC do it LOL. Nice work as alway's, I'm with you on the thin alluminum it's a PITA to weld and make look nice at the same time
T Tanner 76, 911s w/ Webers 76, 914/4 57, Speedster |
Amazing, as always!
MAGA
Wow, it has been awhile since I have worked on this project! I guess spring fever is hitting as I found some time last night and this morning to start working on the bike again. Trying to finish up any mods that might involve frame mods as I don't want to tear it apart for blasting/painting until I am confident I have it all figured out.
After changing my mind several times on how/where to cleanly mount the starter solenoid, voltage regulator and the battery, I finally made up my mind and simply found an out of the way spot that will hide the wiring under the seat while eliminating the stock heavy battery/electronics mount box. I will be using a smaller battery mounted by an aluminum strap down near the top of the swingarm. ![]() ![]() I had a hard time deciding how to cover the gap between my new aluminum seat pan and the gas tank, but I finally decided to weld an aluminum piece to the pan which ultimately will have a thin foam/rubber pad attached to it..... I @#$@#$% hate welding thin aluminum!!!!! It turned out OK after a bunch of grinding/sanding. ![]() ![]() ![]() ![]() ![]()
Senior Member
Tim,
As usual, very nice work. Had to chuckle at your "spring is coming" comment! I just went out today and got the R1100RSL out from under the cover to get ready to ride tomorrow. Fly safe! Joe A
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
MAGA
Well for now I am going to run a stock sized battery and I decided to make a new lighter battery support out of .050" thick aluminum. I had to weld a small tapped lug to the frame tube to hold the front of the new support and simply drill a couple holes in the existing rear frame cross member for the rear. I slightly lowered the battery and had to dent the inner fender a bit to clear the support tray. Just for the hell of it, I weighed the new and the stock battery supports and the new one weighs .15 lbs while the stock one weighs 2.51 lbs. This new one will work initially but I may have to ****can it someday if I get a smaller battery that will fit down low near the top of the swingarm.
Soldier of Fortune
Just curious...why aren't you going with a "battery eliminator"?
MAGA
I am not aware of one that works for this particular make/model of bike. I will use the bike to commute with at times, so the bike needs to stay somewhat reliable. If there is a something out there that works, I would be interested in hearing about it.
MAGA
Time to make up my mind on how and where to mount the rearsets.
1/8" steel plates with tapered 3/8 id bosses look like they will be fairly strong and not too heavy. ![]() ![]() ![]() ![]() ![]() ![]() Crap... with that done, I need to make up my mind whether to make aluminum levers or 4130 thin wall tubing pedals. I spend more time scratching my head than making parts. ![]()
Senior Member
Sure are nice looking welds! Thats how they are supposed to look!
least common denominator
You got some mad crazy skillz there Tim,
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
MAGA
Well some of them look ok.... I should have waited to finish weld them to the frame until I tear it all apart for blast and paint, but I got impatient and the welds are actually kind of sloppy in spots due to gap I was bridging. I am pretty sure the levers/pedals will hide it them though. Oddly enough, the factory Honda welds are pretty chunky on this bike however so I guess I need not worry about it. I can assure you Joe that my airplane fuselage welds are much nicer. ![]()
