Tech guys: Site monitoring, change, etc.
Do any of you tech guys know of a free service that will:
1) Monitor website, SMTP availability? 2) Monitor a blog or other site and check for an update/occurrence of a keyword? I've seen some paid services, but wondering if you know of any tools/service that does this. I want to know that one of my sites is live and that the mailserver is running; and there are some blog sites that I want to be notified if a keyword is used. Thanks, Don
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
The Unsettler
Depending on the level of control you have on the server, ie: is it a dedicated box, you can use webmin.
It has the MON module. Linux only. http://mon.wiki.kernel.org/index.php/Main_Page
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Thanks - I'm looking for something simpler: type in the URL and it will send you an email if it pings the server and finds it down.
Similar with the other feature: type in a keyword, and it will tell if you if a php forum or blog has the keyword posted.
Don, probably you know this but having the server up (reply to a ping) does not means that the SMTP (or any other service) is up. Telnet on port 25 will reply with the SMTP header (meaning the service is up). Check this --> http://www.activexperts.com/activmonitor/functions/smtp/rfc821/ seems to be free (links on top)
Jordi Riera '84 930 (modified) |
