meister member
How can I reprogram the shift points in a 2000 Olds minivan?
I would like to reprogram the shift points for the tranny in our 2000 olds minivan for improved fuel economy. Does anybody know how I could go about doing this? What equipment do I need? Program?
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Bandwidth AbUser
I opened this thread hoping to see another gearhead hot rodding the family car, and what do I find? Economizing! WTF?
![]() Sorry. I hope you can get the answer you seek.
Jim R. |
![]() "Reprogram shifts points...for improved fuel economy", on a minivan: I didn't know you could be neutered twice
1996 FJ80. Last edited by Seahawk; 06-05-2008 at 11:20 AM.. |
Slumlord
Target maket size for that software? 1.
And my guess is you are unlikely to make significant saving in fuel economy. |
meister member
We are getting soaked $150 a week in gas costs and we are living on a limited budget since I am going to school.
Speedy
meister member
Speedy
Did you get the memo?
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
I'm with Bill
One word.
Hydrogen Gererator.
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
Drive less? Buy a Civic? Motorcycle? Bike?
Math was never really my forte', but..........
Slumlord
10% seems optimistic.
Why wouldn't GM do that from the factory? What are you going to sacrifice in drivability to get that? But you can get 10% by doing maintenance, and driving carefully. |
meister member
These suggestions have already been implemented with the exception of the motorcycle. I have one but will not ride it any longer due to safety concerns. Even though I don't have a Civic I do have a crappy Saturn which I may swap out final drive ratios for a SL1 gearing.
Speedy
I find it hard to believe a manufacturer leaves 10% fuel economy on the table due to shift points.
Shift it manually for a while to test your theory.
Randy '87 911 Targa '17 Macan GTS |
meister member
What I want to do is.. 1)Have it hold OD longer during slightly more throttle input like going up a hill 2)I want it to immediately shift back into OD during throttle lift off and reapplication. Right now it takes 2 seconds to shift back into OD 3) lower rpm shift points for 2nd and 3rd gear during light throttle applications. 4th seams OK as it is. 4) lower the temperature the engine has to reach before the tranny will shift into OD during cold start. This alone will see an increase of %50 during the first 3 miles driven. Speedy
I'm with Bill
Just a hunch, are you getting an engineering degree?
meister member
Mechanical Engineering
![]() Speedy
You're worried about a 2 second lag in OD shift?
Oversize tires pumped up to 45psi Cardboard in front of radiator to get it up to temp faster. |
meister member
Cardboard in front of radiator.... Check! done in winter time and taken out now. Anybody know how to go about getting the software to do this???? Speedy
Slumlord
Good luck with this, the tool for accessing the computer portion of the GM transmissions comes in a huge suitcase, and its very, very, proprietary. A modification of the governor valve would be easier.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
