dennis in se pa's Avatar
How to redo old pool side cement
I am moving to a house with a very nice but 30 year old Anthony Pool. The concrete deck around the pool is acceptable, especially for a 30 year old pool. I am wondering if anyone here has had any experience re-cementing, recoating, or whatever might make the cement look beter. Is an epoxy coating an option? I don't want to go to the point where I tear it out and replace it. It is not that bad.
Thanks.
Rev. Dennis
2001 911 Cabriolet
Old 06-07-2008, 02:32 PM
If you are referring to the concrete pool deck around the pool and not inside of the pool then yes I know what you need to do.
Should be no problem finding someone to install a polymer modified concrete topping to the surface. Once the coating is put down in whatever texture style you like, it can then be painted, stained, or left alone.
Epoxy resins mixed with aggregates are also an option but tend to be more expensive than the concrete topcoats.
Randy
'87 911 Targa
'17 Macan GTS
Old 06-07-2008, 07:24 PM
Platinum Member
dad911's Avatar
Cool Deck can be applied over a decent concrete base. Also look into patterned concrete, and concrete stain.
Old 06-07-2008, 07:31 PM
Sultan of Sawzall
rouxroux's Avatar
+1 on CoolDeck, although it's a PITA when it starts releasing after about 5 years.
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 06-07-2008, 07:46 PM
MBruns for President
JeremyD's Avatar
Thin pavers or cool deck
Old 06-07-2008, 08:03 PM
