Brownout?
Sunday morn, we experienced a brownout here. Today, our microwave quite, and we're suspicious about the function of our water heater. Perhaps a burnt out element.
This the first brownout we've ever experienced. Thoughts on appliance damage welcome. Off to buy a new microwave, but will check in later.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Yes, brownouts can damage appliances. The hot water heater only has elements to worry about and those are easily replaceable by a DIY'er...
From the web: http://www.eoq.com.au/beware_electrical_brownouts_during_storms.cfm |
Thanks Danny...Now, anybody here who can give me tips on how to check water heater elements? I have a multitestor that will test 110, but don't have a clue how to test a water heater.
unindicted co-conspirator
is your hot water still hot?
If so, it should be OK
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
A Man of Wealth and Taste
Welcome to the future of America...
Copyright "Some Observer" |
Brownouts are know to destroy microwave ovens.
David 1972 911T/S MFI Survivor |
Make Bruins Great Again
The brownout should only affect the microwave if it was in operation at the time. What brand is it? GE under the cabinet units are notorious from problems with the magnetron unit going bad. They have a 10 yr warranty but it only covers the part and the repair tech will charge $60-90 for a service call plus hourly labor. Total will be $250-300. Google GE microwave and you'll find plenty of unhappy campers.
I argued with them until they agreed to send me the part and I would get a qualified tech to install it. My local repair guy told me how to do it and it was a breeze.Moral of the story: DON'T buy a GE.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
* 15.5 ohms for 3500 watts * 13.0 ohms for 4500 watts * 10.0 ohms for 5500 watts Be sure the tank is re-filled before turning the electric on. An element not submerged in water will burn out within seconds. |
Non Compos Mentis
Test a water heater by opening a faucett and sticking your hand under the water.
A water heater element isn't too finicky about voltage drops. You should be okay. Only three things can go wrong with a water heater- the elements (the bottom one usually goes out first since it works harder), the thermostat, or the tank itself leaks. If the water is hot, but does not last long, the bottom element probably quit. May as well change them both, since they're cheap, and you have to drain the tank down to the bottom anyway. Might not hurt to just go ahead and also change the thermostat while you're futzing with things. Everything you need is over at Home Depot. |
18 years ago we had a brown out, lost a large freezer full of food. The local utility co. paid for the lose.
Von http://vonsmog.com 73' 911T Coupe, 76' 911S Targa 73'& 80' Mercedes Unimog DoKa 59' Austin Healey 100-6 |
Guys, thanks for ALL the info...it's looking like we lucked out. Only the microwave, a "Sharp" brand has been replaced through a quick trip to COSTCO. Water heater and other appliances seem fine.
A special tip of the hat to you, Danny...a print-out of your how to test post has been made, is in the water heater manual. We have frequent power outages here, but this our first brown out. One tip to those with freezers...fill empty milk cartons full of H20, place them in empty spaces. When the power goes, this keeps things frozen longer. An added bonus is when you need ice for a cooler chest just whack the carton with a hammer.
You do not have permissi
The guy behind the appliance counter said that every time there was a brownout their business increased.
Not sure what the solution is, except an uninterupted power supply for applicances. I try and not use anything except lights during the thunderstorms. |
Unconstitutional Patriot
Have made many gallons of biodiesel in a water heater running the element at 115v instead of 230v. It just uses less watts. The element doesn't care what voltage it sees.
There are whole-house line conditioners which typically mount in-line with your elec. meter. If the voltage drops below a certain level, it will cut the elec. until it returns to "normal". Works for over-voltage too. |
Danny...I'm guessing you are an electrician? You are a fount of know-how on the topic. I'm going to ask the electrician who will be wiring Cindy's kitchen remodel about installing a whole line protector. If it saves our appliances once, it will probably have paid for itself?
Check with your local power company. They may offer a unit for a monthly fee. There is no huge cash outlay on your part and if it ever gets fried, it's their problem. Correction: The units offered by the power companies are typically "surge protectors" and will not help with brownouts. You need a line conditioner. Check with Home Depot Commercial Services or a local electrician. Last edited by Danny_Ocean; 06-30-2008 at 06:05 PM.. |
Senior Member
The process that Danny gives is the best way to check them out. They usually are not hard or expensive to change out.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
