jyl jyl is online now
jyl's Avatar
DNS Server Outage - Solution?
Arrgh, Comcast broadband was out of service for the longest period I have ever experienced. Service was out Fri morning when I left for work, Fri eve when I returned home, and part of Sat morning. Previously the longest outage I'd ever had was a few hours, maybe once a year.
Apparently it was a DNS server problem. Some research shows Comcast has had prior spates of DNS problems. http://www.computerworld.com/securitytopics/security/story/0,10801,100960,00.html
Alas, I don't remember the numeric IP of any websites.
Perhaps the answer is to bookmark the numeric IP of Google. 216.239.51.99 And use Google to get to whereever you're going.
Will that work, next time Comcast has a DNS server problem?
Old 08-09-2008, 01:36 PM
Slackerous Maximus
HardDrive's Avatar
Not sure how you are configured, but you could always point your machine at different DNS servers manually. The ip configuration in XP allows you to have a dynamic address and a manually configured DNS entry.
2014 Cayman S, PDK
Old 08-09-2008, 01:42 PM
slodave's Avatar
Won't work. Google will try and resolve to google.com on the first search. Try and use ATTs DNS servers - 4.2.2.2 4.2.2.1.
Old 08-09-2008, 01:43 PM
jyl's Avatar
So simply type 4.2.2.2 and/or 4.2.2.1 into the DNS server box in my network prefs?
Edit: Just did so, seems to work. Mac OS X 10.5
Old 08-09-2008, 04:29 PM
The Unsettler
stomachmonkey's Avatar
A lot of bad/slow ISP service is nothing more than crappy DNS.
"I want my two dollars"
"Brandon Won"
Old 08-09-2008, 06:23 PM
http://opendns.org/
Old 08-09-2008, 09:17 PM
id10t's Avatar
You could run a cache-only DNS server at home/work and use that. Or use one of the many many servers out there. Heck, I've got a DNS server running (authoritive for my stuff, caching for everything else) that you can use if you'd like.
67.18.176.153 and 69.56.173.192
Old 08-10-2008, 05:42 AM
