Converting Exhaust Heat Into Electricity
Interesting Stuff - I love crazy materials!
Why not just hook your turbo charger direct to a generator? Then use the exhaust heat to boil water for your steam turbine, then use the left over exhaust pressure to power an air generator? by the time your done you have more than you started with?
Now, with a gererator, it all makes sense. |
A huge amount of the potential energy from the gasoline consumed by an internal combustion engine is lost to friction and is expressed as heat. Reclaiming that heat to create more energy seems like a no-brainer as long as the device is cost-effective.
You guys are forgetting about the Phlogiston Effect....
Actually, this is very cool stuff. Think of materials optimized for cogeneration from cooling towers, smoke stacks, or anything that generates waste heat. Potentially there's a wide range of devices that could become thermoelectric generators. |
Anything is possible with a gererator!:D
Cool idea and technology. I remember a while back BMW had a gas/steam hybrid engine that used the exhaust and coolant heat to power a small steam turbine. It apparently stayed a concept. It would be nice to improve on the low efficienty of the internal combustion engine, harnessing all of the dissipated heat energy would be a good place to start. |
Just a regular thermocouple generates voltage when exposed to heat.
Speedy:) |
1.5% is crap!
HRSGs (Heat Recovery Steam Generators) in a Power Generation are about 40% thermally efficient. If you recovery the latent heat in the cooling water for heating, it can reach 70%. Also, what is the cost of an exhaust system based on a Peltier generator? I expect it will be friggen expensive! |
| All times are GMT -8. The time now is 04:45 AM. |
