Targa, Panamera Turbo
Converting Exhaust Heat Into Electricity
Interesting Stuff - I love crazy materials!
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
abit off center
Why not just hook your turbo charger direct to a generator? Then use the exhaust heat to boil water for your steam turbine, then use the left over exhaust pressure to power an air generator? by the time your done you have more than you started with?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Monkey with a mouse
Now, with a gererator, it all makes sense. |
Feelin' Solexy
A huge amount of the potential energy from the gasoline consumed by an internal combustion engine is lost to friction and is expressed as heat. Reclaiming that heat to create more energy seems like a no-brainer as long as the device is cost-effective.
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
Tree-Hugging Member
You guys are forgetting about the Phlogiston Effect....
Actually, this is very cool stuff. Think of materials optimized for cogeneration from cooling towers, smoke stacks, or anything that generates waste heat. Potentially there's a wide range of devices that could become thermoelectric generators.
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ |
Did you get the memo?
Anything is possible with a gererator!
![]() Cool idea and technology. I remember a while back BMW had a gas/steam hybrid engine that used the exhaust and coolant heat to power a small steam turbine. It apparently stayed a concept. It would be nice to improve on the low efficienty of the internal combustion engine, harnessing all of the dissipated heat energy would be a good place to start.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
meister member
Just a regular thermocouple generates voltage when exposed to heat.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
canna change law physics
1.5% is crap!
HRSGs (Heat Recovery Steam Generators) in a Power Generation are about 40% thermally efficient. If you recovery the latent heat in the cooling water for heating, it can reach 70%. Also, what is the cost of an exhaust system based on a Peltier generator? I expect it will be friggen expensive!
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
