Need computer help
I am not very computer savvy and am having a problem. I'll be on-line and all of the sudden my modem shows going offline. Then the lights all light up and I'm back on-line. At first it was every once in awhile but now it is happening every 5 minutes or so, sometimes sooner. It is getting quire annoying. I have looked at the connections and everything seems to be working properly, have also run a virus scan with nothing showing up, (Norton).
Can someone explain, (to a 5 year old), how to diagnose the problem? Much thanks as it also affects my Co. laptop as I have a router also.
Thank you in advance
O2 In Sully We Believe
Old 09-07-2008, 05:33 AM
Gon fix it with me hammer
svandamme's Avatar
what kind of modem?
regular antique dial-up , broadband dsl or broadband cable?
Stijn Vandamme
BIMDIESELBMW116D2019
Old 09-07-2008, 07:16 AM
Unfair and Unbalanced
Mule's Avatar
Location: From the misty mountains to the bayou country
If you have dsl, your modem sounds sick. It's pretty common. Call your provider & they'll overnite you a fresh one.
"SARAH'S INSIDE Obama's head!!!! He doesn't know whether to defacate or wind his watch!!!!" ~ Dennis Miller!
Old 09-07-2008, 07:34 AM
what kind of modem?
It's a Motorola SB4101 cable modem, cable connection
I don't think think it's DSL , isn't that dial up?
Thanks guys for the replies
Old 09-07-2008, 08:05 AM
Family Values
KaptKaos's Avatar
Sometimes the modems get wonky and need a reset from the cable company too. Part of your call to them will be a reset. You can do their first step, which will be to unplug the cable modem for 20 seconds (count it out slowly) and then plug it back in. That may do the trick too.
- Joe
Necessity is the plea for every infringement of human freedom. It is the argument of tyrants; it is the creed of slaves. - William Pitt
Old 09-07-2008, 08:09 AM
Slackerous Maximus
HardDrive's Avatar
+1
Unplug it (Comcast says for 1 minute), then plug it back in. If it continues to happen, call you provider and have them come out. The modems they hand out are cheap junk. They go bad. Also, both cable and DSL connections need a nice clean signal to work. Its possible the feed into your house or your internal wiring has went south.
I had do have the cable into our house replaced to keep our cable running properly.
2014 Cayman S, PDK
Old 09-07-2008, 08:23 AM
Mule's Avatar
Cable modems are more reliable. The reset may do it. Do you have a router?
Old 09-07-2008, 08:24 AM
Again thanks guys, I turned everything off last night & unplugged it all, (didn't wait the full 20 seconds though. I'll try that again a bit later. If that doesn't work I'll call then tomorrow. I do have Comcast.
Old 09-07-2008, 08:26 AM
Switched out modem but the problem persisted the first night. The last two evenings have been boot free though. Not your of the gig but thanks guys anyway
Old 09-11-2008, 04:35 AM
