Virginia Rocks!
VaSteve's Avatar
Painting Question - what do I need to know?
I wanted to paint a small motorcycle...fender, tank and a couple of other small pieces. Rather than rattlecan it, I thought that I could learn to paint it with my compressor and a painting kit. (I guess it's only a fancier version of a rattle can ).
Down the road (if I'm any good at it) I figure I could touch up parts of my car that need it. If seen plenty of you guys painting stuff, can I use a kit like this?
http://www.lowes.com/lowes/lkn?action=productDetail&productId=219031-1126-TFK00100AV&lpage=none
I figure the parts are now small so the fact I have a small compressor shouldn't matter much.
Any thoughts, suggestions? What do I need to know??
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 09-28-2008, 08:25 AM
Shaun @ Tru6's Avatar
it's all about surface prep.
Tru6 Restoration & Design
Old 09-28-2008, 08:38 AM
Zeke's Avatar
Looks like a good starter kit. You may find you like the detail gun for frames, etc. Get a filter/trap for your compressor and mount it a few feet from the outlet if you can.
When I get these cheap guns I usually go over them with a glass looking at all the orifices and passages for little chips and things. Having them all working as designed makes for a better spray pattern. Even the fluid needle withdrawing back out of the fluid cap dead on center is very important. Otherwise you get a fat part in your pattern. Of course, expensive guns have all this done before they leave the factory.
Old 09-28-2008, 08:46 AM
Virginia Rocks!
VaSteve's Avatar
I assume you mean the air outlet? Assuming I have a ~20foot hose, where would I mount it? thanks
Old 09-28-2008, 08:50 AM
Feelin' Solexy
Tishabet's Avatar
I have an industrial one just after the regulator from the compressor (i.e. between the compressor and the hose) and a disposable in-line plastic one between the hose and the gun.
If you use your compressor to run tools, you know that they can start spitting water from the lines, and that water will get into your gun/paint without a filter. For a small job like you're talking about, I would just get one of the cheapie plastic ball in-line ones, should be able to find them in the $10 range.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 09-28-2008, 09:52 AM
Platinum Member
dad911's Avatar
+1
Also, I like to use HVLP.
Old 09-28-2008, 11:22 AM
www.autobodystore.com
the pelican parts of the paint world. Forums little hard to follow but great info and supplies.
DBrisson 83sc
Old 09-28-2008, 06:01 PM
Virginia Rocks!
VaSteve's Avatar
Originally Posted by dad911 View Post
+1
What's the difference between that and what I posted a link to?
Old 09-28-2008, 06:37 PM
Friend of Warren
This is an HVLP gun. It is a Devilbiss HVLP Finish Line gun (purchased at Harbor Freight). It is a decent gun and an excellent price and will last a lifetime. Not all that expensive and will make painting a whole lot more fun than the gun you are looking at.
Kurt V
Old 09-29-2008, 06:53 AM
(the shotguns)
berettafan's Avatar
kurt what's the HF model # on that puppy?
been tossing around the idea of painting my R25 now that i have the motor so clean.
Old 09-29-2008, 08:35 AM
Platinum Member
dad911's Avatar
HVLP has alot less overspray, less mess, more paint ends up on the surface.
Old 09-29-2008, 09:37 AM
Friend of Warren
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=92541
Kurt V
Old 09-29-2008, 10:51 AM
Zeke's Avatar
And designed for more modern paints, like 2-stage. HVLP's tend to produce more orange peel with single stage fast dry material, which is my preferred paint.
Old 09-30-2008, 12:00 PM
VincentVega's Avatar
Check your compressors specs against the guns you are looking at. Without enough clean air you wont be happy with the results.
So, changing from brown to silver or black?
Old 09-30-2008, 01:29 PM
faster than I once was...
FastDave's Avatar
Send a message via Yahoo to FastDave
I've painted several ladder racks that I built in my shop with a very small air compressor and achieved excellent results even with the small pump and small tank. You just gotta take your time. Since you're only painting a tank I don't think you should have to worry so much about your air compressor specs.... unless you're a real "tech head" and then you'll want to go buy a newer, larger air compressor since this one job really does justify the expense! lol
~Dave
Old 09-30-2008, 02:14 PM
Rick Lee's Avatar
I'm painting my bike soon too, but will rattle can it. The way my bike is built, you can just take each plastic panel off and do it as you get to it.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 09-30-2008, 02:15 PM
Virginia Rocks!
VaSteve's Avatar
It's a small compressor. I'm pretty sure I can get enough air to do the parts I need done, I just need to make sure It'll run the gun!!! How can I tell???
I haven't completely decided on a color yet. I like white, black or maybe a dark red. I want to avoid metallics and crazy stuff since I've heard it's tougher to work with. The bike is pretty scratched up from 28 years of first time riders. It needs some help.
Old 09-30-2008, 05:00 PM
Double Trouble
targa911S's Avatar
All who have posted are giving you the BEST advice. Prep is where it's at for sure. Painting is the easy part.
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 09-30-2008, 05:33 PM
MAGA
Tim Hancock's Avatar
Steve, believe it or not this $15.00 Harbor Frieght gun works pretty good. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=47016
I picked up a couple for the machine painters at work and I tried one out spraying Polane (similar to Imron) and it work just as good as some of my guns I use at home for painting cars, airplanes, motorcycles etc. These cheap knockoffs are a lot better than they used to be. FWIW, I prefer these gravity fed new fangled guns over my older suction feed guns. To get the best finish out of most guns, it is usually best to crank the pressure up to at least 50 psi even though the directions on the paint or gun may suggest lower. You will get better atomization of the paint for a better finish, but will waste a bit more paint. (good for the finish, bad for the EPA nazis )
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 09-30-2008, 06:00 PM
Virginia Rocks!
VaSteve's Avatar
Yeah, I already knew that. I didn't know anything about equipment. I'm pleased to see that I can get equipment relatively inexpensively.
Old 09-30-2008, 06:09 PM
