Beats 12k dial up. which is the only other option out here. Mine has been particularly slow lately.
I guess living in Cali is not all bad
ßrandon |
My incoming was like 264 and my outgoing was like 314. of course that is with the download running. my g/fs incoming is like a 31,000. of course she does live on campus at OSU its like having a T1 in your room.
FYI: A T1 is 1,544 kbps
ßrandon |
Ok. well i said like. its still mega fast. and i am down to less than an hour left on the ubuntu download. have to go to bed so im gunna have to let it finish without me
sudo apt-get purge 930
![]() Sorry for the hijack, porsche4life
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
Cars & Coffee Killer
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
got started installing and it wants to connect to the internet. thats not a possibility until i can get it online wirelessly what do i do?
If you downloaded the full version then just skip that part and continue with the install. You can configure the wireless card later.
I'm sure you already did the Google thing but go to this Ubuntu wireless setup site for setup. Worked like a champ for my workstation wireless.
I downloaded this version and it only gives me the option to retry or close.
bump still stuck
You don't need internet connectivity to install Ubuntu with it's default set of packages. Are you trying to customize the packages during the install? If so that causes it to attempt to look at the default repositories for any dependencies.
ßrandon |
All i am trying to do is the install. I run the install and it says it could not connect and gives me the option to retry or close. Im not trying to do anything special
Did you try selecting close? It should bypass that if you select close.
Let me give it one more try but when i did that it close the whole install last time.
Ya it cancels the install.
Boot from the CD, don't run it from within Winblows.
ßrandon |
Correct. You should have the CD with the Ubuntu iso burned to it, in the CD tray, and when you reboot it should automatically launch and run Ubuntu. On the desktop are two icons. One of them is the installer. It should just talk to the CD - no internet required. WARNING - installer will format your hard drive so anything on there should be saved first.
